New WoodChat!
OT - Dad would be so proud (bit long)
I'm doing the outside trim on our shed conversion (to workshop for my wife: wiring, lights, insulation, floor; all the fancy stuff). Our Queen Anne house uses a trim pattern with a molding on the head casing, like this (in section):
It projects 2-1/2", and needs a custom flashing. The flashing runs up the wall a bit, then down the front and both ends of the board atop the head casing. I spent a few months working for a local sheet metal shop years ago, and learned there that soldering is best for flashing details like this. I also learned (sheet metal) soldering well enough to do it flat; but I never mastered soldering vertically*, so I needed some way to keep the flashing upright, so I could solder the rather complicated end bits, which have a couple of parts.
The picture below is what I came up with.
Now, to the subject line of this post: my father, following in his father's footsteps and consistent with his era, was fond of coming up with slightly outlandish devices to hold work in place in the shop and around the perennial remodel of our house (started when I was five; didn't get entirely finished until we sold the house a couple of years ago).
I think he'd have approved of my solution today.
*It can be done: you get the solder flowing and draw it up the flashing with your soldering copper tip - the solder will flow toward the heat. Not easy, though.
Re: OT - Dad would be so proud (bit long)
Bruce, a MN Galoot
First, Bill,
Soldering tin, especially flashing like that, is a skill that is so foreign to me, it leaves me in amazement at your abilities.
Second, why is soldering that joint preferable to simply bending it?
Very nice job!
You do bend it; but you can't bend sheet metal in three dimensions (around the ends of the board, for instance) without an opening that needs to be soldered shut. I'll try to take some pictures tomorrow, to show the soldered joints.
It's really not that hard; it just takes the right tools (soldering coppers, available at a lot of estate sales of the right sort) and practice.
Pictures and some rambling (long)
The corners of the flashing look like this on the front side:
and like this on the back:
and like this installed:
It's been a while since I made one of these, and I realize two things: one is that I did it wrong: the piece that fills the back corner, which is behind both the end piece running down and the up leg that will go against the wall, should run in front of the up leg, to provide a mechanical interlock. It's easier to solder that way, too, as you can rest the flashing flat on its back and solder the piece to the up leg all around. I'll have to decide whether to redo it tomorrow (today's fun project was maintenance on the one of the cars, which is due for smog testing).
I also didn't allow quite enough clearance, so I'll need to do a little hammering and cursing to get the flashings to fit. You can see that this one is slanting up slightly to the left - it doesn't want to rest on top of the casing, coming a little short at the other end.
Digressing...
For those who want to learn sheet metal soldering, by the way, don't try to do it with a propane torch. Go to estate sales or haunt junk shops until you find a soldering copper, a big hunk of copper attached (in various ways) to a steel shank and wood handle (the handle's often missing, but any large chunk of wood jammed on the end of the shank is enough - you don't need a beautiful turned handle). You heat this - I use a propane torch, my son uses his MAPP torch, the ideal is a portable propane "stove" with a hooded burner to retain heat and space for two coppers, so you always have a hot one.
You need to apply flux to the galvanized metal. I use the classic muriatic acid; some people are nervous about this and use more expensive soldering fluxes, which work fine too. The hardest part is finding the big bars of solder, which weigh about a pound and are 12" or so long. I've got a supply picked up at garage sales, but you might have to go to a supply house that supports sheet metal workers. The second hardest part is opening your wallet to pay for the solder, which is mighty pricey.
You need to clean and tin the copper. Sal ammoniac, the classic cleaning material, is REALLY hard to find now; I file the copper smooth on the operating end, get it hot, flux it a bit, and apply the solder to it. As you heat it in the course of soldering, keep the tinned part clean by wiping it on a wet sponge.
You melt a little solder on to the fluxed galvanized flashing, get a pool going, and move it around with the copper, making sure it goes UNDER any seams. You can move the wet solder around with the copper and draw it under overlaps by moving the copper along the overlap. If the copper is hot enough to melt the solder instantly, it's fairly intuitive.
Once you learn how to solder, you can do flashing details that will last way longer than any details you could do with pop rivets and caulk.
