New WoodChat!
Bedrock 603 refurb and rosewood knob repair
Dominic in Buck's County PA
Hi gang,
Last week I picked up a nice Bedrock 603 from Tom Wiadra (from WoodNet). While totally functional in all respects the plane arrived with a dinged knob (courtesy of USPS ) and a bent threaded rod. Tom is sending a new threaded rod. But didn't have a replacement knob. Since I had another knob to repair as well, I decided to fix it myself.
bent threaded rod on knob
I found a couple scraps of rosewood (from an old broken tote) in my junk pile and proceeded to sand a flat at the broken portion of the knob in order to receive the patch
Rosewood knobs
I mixed some 5 minute epoxy with some charcoal dust (obtained from a charcoal pen I had) in order to get it as dark as the rosewood. Otherwise the glue line would stand out.
Rosewood knobs
Here are the knobs clamped up and ready to go. On all the patches, I was careful to orient the grain as close to that on the existing knob. In the case of the small knob for the 603 I needed to make two patches. That was done by gluing the one in place, allowing it to set, then sanding another flat and gluing the second on in place.
Rosewood knobs
I used a pen mandrel to hold the knobs while I turned the patches to the correct profile. All the time I did this I kept taking small bites. You don't want to generate a lot of heat, nor overstress the bond of the glue. After the patch was turned smooth, I sanded both knobs to about 300 grit. The tote was stripped using lacquer thinner and given a light sanding. Then I finished them all with shellac.
Rosewood knobs
Here they are. The small knob is right at home on the 603 (I stole a threaded rod from another No3 I have )
Bedrock 603 Type 7
While I was waiting for the epoxy to dry, I worked on the rest of the plane. I disassembled and wire brushed the entire thing. All the parts were given a coat of oil and were allowed to sit overnight. The next day they were wiped off and re-assembled.
I paid special attention to the plane iron because I wanted it to be "worthy" of such a cool little smoother. I reground the bevel and then flattened the back using my flattening plate and diamond paste. After that the bevel was honed to a fine edge. I also took the time to relieve the edges of the iron so that it would help to reduce the "plane tracks" left when smoothing. I think I might go back and camber it a bit.
And here is the money shot!
Bedrock 603 Type 7
Bedrock 603 Type 7
Bedrock 603 Type 7
Thanks for viewing!
See ya around,
Dominic
Re: Bedrock 603 refurb and rosewood knob repair
Jim DeLaney, Austintown, Ohio
Nice repair - and great tutorial, Dom!
Bruce, a MN Galoot
Nice job, Dom. Sure wish I had your resources. I've rarely seen a 603, not to mention find one in the wild.
Dominic in Bucks County PA
Thanks Bruce! But to be honest, I thought I'd never find a Bedrock 603 for anything less than buying a new LN No.3! I just lucked into this one. Because he knew I was looking for one for the better part of a year, Tom Wiadra offered it to me for $80. So I jumped on it like a monkey on a cupcake!
I don't know Dom...
Scott Burr in Ben Lomond CA
Those shavings look a bit thick to me :D
Great job as usual.
Thanks Jim!
