New WoodChat!
Making cauls...
Making cauls...
Making cauls...
Scott Burr in Ben Lomond CA
I need 2 pr. of these for the upcoming glue up of the blanket chest project.
The cauls will be 32" long. What kind of arc should I put on them?
I was thinking of measuring 1/8" off of the a center line of a 2X at each end and making a scribe arc. Then run it through the BS then run the other one through making 2 cauls from one 2X4 (yes, one day I'll own a turning saw :D ).
Re: Making cauls...
Re: Making cauls...
Marv
Scott,
I have read that a caul is something a few people are born with. Something having to do with the face. :\
Marv
Re: Making cauls...
Re: Making cauls...
Bruce, a MN Galoot
I made a couple cauls from 2X4's, only mine were about 2.5" thick at the center. The arc may not be uniform because I mostly freehanded it. I just put a bending strip against two nails and scribed the resulting curve. It's about 3/16" for no particular reason. It produced pretty good joints, using short pipe clamps on either end.
Re: Making cauls...
Re: Making cauls...
I managed to misplace the cauls I'd made for some project or other. I basically just planed several strokes off the ends of the board and then blended the resulting irregularity into a kind of curve. Worked well for me.
Re: Making cauls...
Yep, especially when they spend...
Way too much time with their heads clamped in a saw vise :D .
Now you sick puppy, why didn't you post your saw bench over here?
At least send me the link to your dark side post. I want to see it again.
Please?
Re: Making cauls...
Making Curved Cauls
Steve Elliott
I've made curved cauls a number of times and have come up with a method that gives me the right amount of curvature the first time. I just hope I can explain it clearly. Here goes:
1. Mill up rectangular stock of an appropriate size. I like poplar because it's cheap, even-grained, and doesn't split easily.
2. Decide which clamps you want to use. I usually go for Bessey-style fast action clamps but for larger pieces a bar clamp might be better.
3. Get an assortment of thin shims--not tapered cedar shims, just little pieces of scrap wood. Put a few of them under the middle of the caul stock and try clamping both ends of the caul down onto a rigid benchtop. By adjusting the shims you can decide how much clamping pressure you want to use.
4. With the caul under clamping pressure, draw a line parallel to the benchtop across the caul at the height of the top of the shim.
5. Release the clamps and then remove the wood below the line on the caul. For multiple cauls of the same size I make one, test it, and then use it as a jig to mark the others.
I hope this sketch makes things clearer.
Re: Making cauls...
Brilliant!
Re: Making cauls...
Re: Making cauls...
BilWil
Here is a description of yet another way. Lots of detail and pictures.
Re: Making cauls...
Re: Yep, especially when they spend...
Marv
I left it posted there for about four hours. They totally ignored it so I deleted it. No one was interested in a saw bench painted John Deere green. Hell, they didn't even bother to laugh and jeer at it. :D
Leif Hanson is going to feature it on his website soon. I'll let you know when he has it up.
Marv
Re: Making cauls...
Please, let me know...
See Marv you should have posted it here. You would have gotten more jeers than you wanted :D
Re: Making cauls...
Re: Making Curved Cauls
Alan S
That looks like a good idea, but I figure the most important thing is that cauls used on opposite sides are the same, so that tightening down makes the pair straight. I don't care if the applied force varies a bit down the glue line, as long as it's balanced.
So my modified procedure is to double your approach. Take two blanks, and clamp their middles together, with spacers between their ends. Mark a straight line on each, then release and trim to the line. This makes sure each of the two has had the same amount of force applied. As long as your trimming doesn't change the two significantly differently, the pair of cauls should be well balanced.
Re: Making cauls...
Am I picturing this right?
Steve Elliott puts the spacer under the middle, which should result, once the planing-to-the-line is completed, in a caul that curves up at the ends. If clamps are applied to the ends of the caul, the force will be applied from the center to the ends.
Alan puts spacers at the ends of the boards, strikes a line, then releases pressure and planes to the line. Alan, won't your cauls then be hollow in the middle? This would be fine if your clamping program was to apply one clamp to the middle; it would be kind of like a sprung joint in panel-making. But most discussions of cauls that I've seen assume that the place you can reach with the clamps is the ends of the cauls. If I'm picturing it right, your cauls would apply no force in the middle.
Likely, I misunderstood; I await getting smarter, or at least less dumb.
Re: Making cauls...
Anti-Wobble saw bench *LINK*
Marv
Scott,
Leif has posted the article on his website. We had some communications relating to the two legs that are splayed. He drew the PDF sketches with the legs angled only one direction. It was my fault because I didn't give him both compound angles. The legs are actually splayed so they are even with the outer edge of the top.
Marv
http://www.norsewoodsmith.com/
Re: Making cauls...
Maybe I should have...
Marv
used dovetails and mortise and tenons and planed the top to .002 flat. :D
Re: Making cauls...
I don't need no stinking shooting board
Marv
