Greene and Greene side board/entertainment center
Scott Burr in Ben Lomond CA
Well I finally got the pics of the camera and re-sized. Hope you like it. I want to give a big shout out to Robert Lang, for his book and all the help I received from him on this forum was a great help. As well as all the help I got from everyone else here.
This is was use to sit in my living room. It was made from a recycled futon frame, a few carriage bolts and a circular saw and a power drill. Boy have I came a long way sense then.
Pretty hideous eh.
Well the old Sony died a while back so it was time for a upgrade on both accounts. Here's how it looks now:
It was made with only hand tools except for a little help from the band saw make the side panels and front door to house the sub woofer.
Here's the branches they were drawn up on my CAD system. The patterns were printed out tacked down and cut out. The vertical branch is Mahogany (as well as the rest of the sideboard) The horizontal is Jaharra (sp) and the 2 small ones are Walnut.
On to the filler panels, Oak ply that was ebonized with India Ink. Note how the grain
Here's the completed sides. Note how the grain in the oak is contentious across and down the panel.
Let's move on the sub woofer drawer. I was made the same way as the side panels mostly, except no filler panels to let the air through. Instead I used 3/4" acoustically transparent black foam, cut the same way with patterns.
Here's a close up of the jointery, with the Ebony plugs
The case construction is straight forward MT pinned with ebony plugs. The shelves and vertical partition are housed in 1/4" grooves screwed from the sides with plugs like most G&G work. The decorative bead on the bottom rail was made with my trusty Preston reeder. I had to grind a blank to make it because stock Stanley (or LN's) can't make this profile. I have one of those mammoth sets of blades for then as well, but no such luck to make a simple groove.
The drawers were difficult. I've never made box joint fingers before. I cut them out like dovetails after drilling 1/4" holes at the base to get that rounded look. They are glued and pinned. The backs slide in and are glued. Each drawer holds 320 CD's and few less DVD's. I was worried about the drawer slides strength so a bit of FEA work took the worry away their plenty strong. All the handles were carved by hand. I have a good amount of pics of this process. If anybody is interested I can put a little article together. Here's a close up of the slides:
The top has bread board ends with pretty much standard G&G details:
I'm open to comments good or bad, Thanks for looking.
