New WoodChat!
Not a typical fiishing question....
Edward in Vancouver
A while back I posted seeking advice on what species of wood would best suit my needs for replacement shelving in a commercial 2 dr upright fridge, and a freezer.
Among the choices were teak, mahogany, Ipe I think, and Doug fir. The power of the wallet won the day, and Doug Fir was chosen.
I need 12 shelves and I'm currently glueing up #7. One of the reasons I'm so slow in glueing up is I need 24 clamps (albeit "C" clamps...) for each shelf.
Now my thoughts are towards finishing. The wood is Doug. Fir, and Doug fir, when wet, does have a peculiar odour to it. Not nasty, but peculiar. And "stuff" in my fridges--bulk butter, eggs, buttercreams, finished cakes, ganaches, fruit purees, etc. have an opportunity to pick up odours if exposed.
I know that shellac is a great odour inhibitor, but not very durable.
Originally I had wanted to finish the shelves with either mineral oil or tung oil. Basically no film finishes, as a film will eventually flake and fall off, or get chipped. Oil, of course, can be re-applied when ever neccesary.
Looks don't factor into the finish, as no one but the cakes will see the finish or the shelves....
Is it possible to apply oil over shellac?
Any other suggestions?
Best regards
Edward
Re: Not a typical fiishing question....
James Watriss
Your application is unorthodox. So I see no problems with using unorthodox methods.
Shellac does seem like the best choice. It's non-toxic, food-safe, And it does fit your budgetary constraints. I think I'd dilute it a lot with denatured alcohol, make or find a leakproof tray or bucket, and submerge the shelves in the really thin shellac. Drilling a few holes in each shelf for air flow will also help the shellac to soak in. Let it soak for a good day or so. Let it dry for several days, and then top each shelf in something like baking parchment. Wrap tightly, and tack the edges down, to keep it tight. Brush a light coat of plain denatured alcohol over the outside of the paper.
The denatured alcohol will seep through and help a little of the shellac fuse to the paper, but as long as you don't really soak the paper, the outside should stay pretty clean. The fibers of the parchment that are touching the shelf will 'hook' into the shellac that's just been exposed to the alcohol, but the silicone in the parchment should help keep your food containers from sticking to the shelf.
I'd stay with shellac. Anything else will give off fumes of one sort or another that will get into your food. (ew.)
Steve Schoene
Yes, I'd second the idea to not use an oil based finish. In a closed space, the smell would be forever. Shellac should work fine. It's tougher than you think.
Edward in Vancouver
O.K. then, Shellac it is.
BTW, the shelves are made of 7/8 stock, two sides @ 26" and two ends at 22", these are 1 3/4' wide, and a middle strip also 1 3/4 wide. In between the two "halves" I have 4 slats each 7/8 wide. Basically it mimics the open grid of any other commercial fridge shelf.
At 12 shelves it is a lot of work, and I'd like to say I used only hand tools, but it's not the case. My crosscut panel saw sure came in handy cutting up lengths of stock and my jack for removing twist and my block pane for fitting the pieces, but the rest was done with "other" tools.....
