New WoodChat!
200+ woodworking book reviews
Adding Cheeks to a Krenov-type Plane
Re: Adding Cheeks to a Krenov-type Plane
scott grandstaff
scott grandstaff
Way to go Derek!! I like this project.
Adding cheeks?? Brilliant!! Excellent improvement.
The plane jumped to life, for me.
So, I couldn't see in the pix, how was hiding the filled holes where the crossbar used to be? Having just been messing with this, I'm curious which way you went.
I am a little worried about the wedge holding up with such short grain above the slot? Tassy oak might be really tough stuff though. Never tried it.
yours Scott
ThomD
I'd v-chisel out a shaving in that glue line, and then polish the wood with crazy glue and sand paper to eliminater the obviousl glue line. Many guitars are pretty much head together with invisible crazy glue patches
Thanks Scott.
To fill the cross bar holes I simply glued in a dowel and planed it flush. I did find it interesting that the old crossbar hole was precisely in the centre of where the new wedge fitted.
(what looks like a gap at the lower end of the cheek is in fact the shadow of where the end tapers inward)
Tasmanian Oak is a eucalypt (just termed "oak" by the early settlers because it has the colour of English oak). It is about as hard as US White Oak.
I am not concerned about the longevity of the Tassie Oak. It should be durable. It has an advantage over some of the harder Oz woods in that it has a bit more flex and give. In any event the end grain is the side I chose to face out as it is better able to cope with impact. Is that not your understanding as well?
scott grandstaff
scott grandstaff
Mornin Derek
I wasn't nit picking anything. Didn't even notice that shadow or whatever that you pictured.
I just wondered if you faux painted the dowel ends, and if you came up with any better tricks than me to make it easier next time. I had a tough time of it on the bureau.
And wedges are kind of notoriously fragile. They all are. You have to take away so much of the wood to get them to work.
I'm always scheming on making them heavier, however I can,
And here you boldly scooped out the whole middle!
This is something I usually do a lot of, pain in the butt, carving on, trying to save every microgram of wood that I can.
But if yours works out good it sure would save me a lot of work next time!
yours Scott
Hi Scott
I didn't get what you meant about the dowel ends before. Now I understand - any attempt at faux painting on my poart would just be a faux pas! :) You leave us all for dust on that score.
With regards the size of the wedge, it would be interesting if others have a view. I don't believe that they need to be large - just so that they spread the load across the blade to damp and hold it securely. I have used this design on a few other planes without any issues arising.
Moses Yoder
Re: Adding Cheeks to a Krenov Plane
Moses Yoder
Have to admit when I read the title I started wondering what modifications you were doing to improve your Krenov plane :D
making it cheekier, of course
Bob Hackett
I`ve seen Leon of Crown Planes fame make wedges like this in some of the later planes.
If you`re worried about strength thru the end grain you could always drill thru what`s left and epoxy that pin you`re no longer using there for reinforcement. :)
Be careful...
Bob Hackett
You don`t want it to become butt ugly. :^(
Perhaps we should put this subthread behind us
