New WoodChat!
New Toothing Plane
New Toothing Plane
Stephen Shepherd
New Toothing Plane
Stephen Shepherd
I just finished up another toothing plane [the second one I have made] which is for an order I received while teaching workshops on Hide Glue at the Piano Technicians Guild convention in Las Vegas at the end of June.
Made of maple, the grain is not oriented correctly [like most planes] because of the size of wood that I had. All hand made, I drilled the mortise from both sides to prevent the 1/4" twist auger from drifting. I used chisels, a pad saw, a rasp and a float to finish up the mouth and throat.
The blade is a standard Buck Brothers replacement blade for a block plane and I filed in the serrations on the back side of the blade. After finishing the plane and the final fit up of the blade it was 1/16" out of square. I checked the wood and it was square but the blade needed a couple of minutes at the grind stone to get it square.
I used the pistol grip hand saw to rip out the wedge for the plane. The new owner will be picking up the plane today, it is a trade and he is bringing me the items we agreed to trade.
Stephen
Re: New Toothing Plane
Stuart Hough
Looks great, Stephen. I'm sure the new owner will get a lot of satisfaction from it's use. How far back on the iron did you file the teeth? I'd also be interested in how they hold up through the subsequent sharpening sessions. Real nice work!
Stephen Shepherd
Stephen Shepherd
Stuart,
Thank you. The serrations are about 3/4" long on the flat side of the blade. It is sharpened just like a regular plane blade, taking care not to score the stone.
Stephen
bugbear
The throat is much narrower than the three "original" (English) toothing planes I have; is your design a deliberate variation?
BugBear
Stephen Shepherd
Stephen Shepherd
BugBear,
My original American and English toothing planes have larger throats. I made the second one similar to the first one I made [of curly walnut] which also had a narrow throat.
I wasn't sure how the first one would work with a narrow throat, but it works just fine, so I made the second one with the same narrow throat.
Stephen
