New WoodChat!
Veritas - Innovation in Tools
The best tips are the simple ones *LINK*
I spent today at a workshop on box making and veneering run by Andrew Crawford (who very modestly calls himself a "box decorator". His work is amazing. Link below).
At one point I noticed his steel rule. The reverse had sandpaper glued along its length. Here it is (on a blow up of a veneer he did) ..
I had to convert one of my steel rules as soon as I got home. Here it is with 240 grit on the rear.
Note to keep the edges free I bevelled the sandpaper with a sandpaper block (if that makes sense).
Verdict: Perfect nonslip. Marking will be so much easier in the future.
Andrew Crawford
Re: The best tips are the simple ones *LINK*
David Barnett
Thanks, Derek.
David Barnett
Inspired me to pull out my Crawford books. His execution is flawless and his instrument decorating techniques applied to boxes set the standard. I'd love to take his workshop. I'm truly envious.
bugbear
Some draughtsman's rules used to have (VERY thin) cork on the back for the same reason.
BugBear
Frank D. in Montreal
I've gotten several rulers with cork on the back, but the cork is thick enough to cause parallax errors, so I always remove it. Not to say that everyone should, but the sandpaper increases hold without significantly raising the rule off the surface.
