Help with Unidentified Glue Removal?
Tom MacGregor
A neighbor asked if she could "borrow a couple of the right kind of clamps" to glue a cracked headboard and I suggested that bringing it to my shop might be the easiest thing to do. I was stunned when she showed up with the headboard from an early 19th Century rope bed made of magnificent birdseye maple - including the frame & panel board and four inch diameter posts! Every glue joint had failed in the frame & panel, so that's going to be easy to clean and repair. Above that the top of the headboard is a single piece of 7/8" thick maple 14" wide that has cracked along it's entire length twice. The newest crack is clean enough to glue up without much trouble, but an older similar crack was poorly repaired (not lined up well) and has failed across about half its length; the rest is still tight.
I'd like to disassemble the older crack, but pulling the loose side open a ways did not make the rest fail. I think from the small amount of visible squeeze-out that it's modern white glue but can't be 100% sure. Any suggestions on how to proceed would be appreciated.
