Good question; never sure of anything (long)
A good question, Stephen, that spurred me to do a little research.
I own a number of Yankee (both North Bros. of Philadelphia, for whom I have a soft spot because my sweetie's from Philadelphia; and Stanley, after they bought North Bros.) and other brand screwdrivers and push drills. I had always thought that one of the differences between push drills and spiral screwdrivers was that the push drills turned more times per push than the screwdrivers, sacrificing torque for speed. Poor observation on my part; the measurements below at least Yankee push drills go farther per turn than screwdrivers, meaning more work per turn, meaning (presumably) more torque per turn for the push drills:
North Bros. No. 135 screwdriver turns 2-1/2 times in 3-3/8" of travel, for 1.35 inches per turn
North Bros. (Stanley) No. 45 pushdrill turns 1-1/2 times in 2-1/4" of travel, for 1.5 inches per turn (confirmed by testing a North Bros. No. 41, the classic chrome push drill)
There are several engineering and operational differences between the two tool types:
1. The spring pressure on the pushdrill is signficantly greater than on the screwdriver (the 135 does have a spring return). I can hold the screwdriver chuck in one hand and the handle in another and operate it easily. Even though the chuck collar on the No. 45 push drill rotates, I found two-handed pushing very difficult, and wound up counting rotations by drilling into a piece of scrap.
2. I mentioned that the chuck collar on the No. 45 rotates; it does not do so freely, and is quite a bit shorter than the chuck collar on any of the screwdrivers in my shop. Also note that early North Bros. chucks screwed to tighten/loosen bits, and this is true of all the chucks on the pushdrills in my shop that use grooved or cruciform bit shanks (Goodell-Pratt, Craftsman, Dunlap).
The chuck collars on the screwdrivers all rotate freely, and this characteristic (and the relatively long collar) has appeared every spiral screwdriver of the Yankee type (I use this descriptor in the loosest possible sense, kind of like "Kleenex" for facial tissue) I've ever held in my hands.
3. I've never seen a Yankee-type push drill that had a "locked closed" setting. Some of the cheap and embarrassing later vers
I briefly and very unscientifically checked these results against other examples and makes of screwdrivers and pushdrills, and found them consistent.
I deduce a couple of things from this:
1. I'm really not very observant.
2. Strong spring returns make sense for push drills, as most of them rotate in reverse as the handle returns, which helps to clear swarf (this can be a problem in larger sizes, I've found; sometimes the swarf friction is greater than the spring pressure, and I have to let the handle "ratchet" in my hand as it returns, and even remove the bit to clear swarf. Past the halfway point in sizes of drill points in pushdrills, I usually get out another drill type...but I digress). Strong springs would probably make less sense for screwdrivers, as, if the bit escaped the slot during return, a stronger spring would do proportionately more damage to the work.
3. The longer, free-rotating chuck collar on a spiral screwdriver supports holding it between two fingers while driving screws, often quite helpful, especially on slotted screws, and an aid to keeping the bit from dancing across finished work. A push drill, once it begins drilling, is located by the hole, and two-handed operation is not necessary.
Now then, turning to the Forsberg "Whale" device (model No. 71, by the way) that was in my original post. This turned 2-1/4 times in 3-15/16", a ratio of 1.75 inches per turn, on the FAR side, from the screwdriver, of the difference between the North Bros. screwdriver and pushdrill. This would imply that Stephen may have been right: maybe it is a pushdrill.
However: a) it's got no return spring (could it have? perhaps, but there's no grunchiness implying loose parts inside, and I'm not sure where a spring could have gone. I believe those are usually coil springs, and a coil spring will continue to provide springiness even when it's broken); b) the chuck collar is long and free-rotating, as if designed to be grabbed in use; and c) there is a "locked closed" setting, for the application of torque when the pushing torque is insufficient.
From these facts, I conclude that it is probably a screwdriver.
