REAL MILK PAINT
Questions on a No.30 level
Edward in Vancouver
Picked up a No. 30 adjustable level today. In nice shape, remarkabley void of paint splatters or hang holes. One glass bubble is missing, and another bubble's round brass faceplate has non-factory screws holding it to the body. This glass bubble is thinner than the main bubble, and judging from the generously applied and mounded plaster holding it in place--and fom the non-factory screws, appears to be a replacement.
I have canabalized a pos (Defiance, I think) level for a replacement clear glass bubble. Appears to fit quite well in the brass housing. What do you fix it in place with, plaster?
Can I use the fixing screws that hold the adjustable mechanism as mounting screws for the brass face plate? Or is there some source on-line where I can get two replacement screws? I understand Stanley had some wierd threading.
I plan on lightly sanding the body and applying few coats of b.l.o. I'm guessing the body is some kind of birch or maple? There appears to be faint traces of red stain in the grip-grooves.
As with every tool I own, I need it for a "user", and have no intentions of collecting.
Re: Questions on a No.30 level
scott grandstaff
Re: Questions on a No.30 level *LINK*
scott grandstaff
This is a Disston 30 or a Stanley 30 or what?
Either way cherry was a favorite wood for levels.
Replacing vials is here. Look down to the bottom of the page.
Your screw issue?? I'd need considerable more information to make even an educated guess.
But no, there is no retail for you where you can buy old screws, unless you are fantastic lucky.
your Scott
levels
Stephen Shepherd
Plaster
Stephen Shepherd
I mix the plaster up with some thinned down liquid hide glue and just a small amount of alum. Too much alum and the stuff becomes unworkable. This is more durable that straight plaster of Paris and water and the alum makes it waterproof.
Stephen
Re: Plaster
Edward in Vancouver
Thanks for the information, gentlemen.
It's a Stanley #30, 24", and weighs a "significant" amount.
Maybe I can chuck the replacement rh screws in my lathe and "turn" a countersink bevel to them and file the tops flat. The factory ones are much nicer, blued steel, but I only have 2 and need four.
Re: Plaster
John Veerkamp
brass screws in a wide variety are available from better hardware stores. I don't know where you live, but the one in town near where we live has countersink brass screws. Look for a store that stocks Hillman nuts & bolts.
Re: Plaster
Edward in Vancouver
Thanks, know of a couple of places that stock Hillman.
