Save my sander!
Save my sander!
Save my sander!
Eric Gertler
I have a Craftsman palm sander that has served me well for many years, and seems to have many years of life left it ... except: one of the little metal clips that holds the sandpaper to the vibrating plate is gone. There is no replacement part available. Anywhere. Yes, I have asked Sears. I even spoke to a human being.
The idea of throwing away this perfectly (almost) good tool makes me very sad. Can you help me save this guy?
Thanks
Re: Save my sander!
Model #?
DaleLenz
Re: Save my sander!
Re: Model #?
Eric Gertler
315.116020
Re: Save my sander!
A couple of comments *LINK*
You might get more information on the main board. We officially don't talk about them electric-powered things here, although many/quite a few/maybe most folks here use electrons.
You might also get some help on Old Woodworking Machines, linky below. You have to register, but it's free. Post on SWARF (Stuff without Arn Related Facts), I think.
http://www.owwm.org
Re: Save my sander!
How about
Wiley Horne--So. Calif.
using it with PSA (pressure sensitive adhesive) paper, pressed right onto the pad?
Wiley
Re: Save my sander!
Consider this ..
Hi Eric
This is the non-electric end of the forum ("the dark side"), and you should get more responses on the end that is lit up.
That said, there are two points to make.
The first is the obvious, that is, one reason many here prefer handplanes is that they are dustless.
However it is the second point I want to stress: you desire holding onto an old palm sander. I know nothing about this particular model, but like many (most?) herte I do also use power tools, and this includes sanders (just not very often).
I have just upgraded my vacuum cleaner from an noisy and dusty old Shopvac (which thankfully sucked up a rubber glove and promptly expired) to a Fein plus Dust Deputy. I attached this to an old (10-15 years) Festo ROS - and lo-and-behold no dust! The point I want to make is that your old Craftsman may not be able to link to a vacuum cleaner and, if so, you are running a health risk by continuing to use it. What is the price you put on your health?
Re: Save my sander!
P. S.
You can get a wonderfully satiny finish by wet-sanding BLO with just such a tool. In that situation, you're not interested in the wet swarf getting sucked up into the exhaust holes, so solid PSA is excellent. Just go through the grits, down to 320g. I won't detail the process, but look up 'wet sanding' and you'll come across plenty of information.
Wiley
Re: Save my sander!
Re: Consider this ..
Eric Gertler
Thanks everyone, I appreciate your help. I was talking with a guy at the hardware store, who suggested i buy a replacement part for a similar sander and "customize" it. Duh.
Tools without motors? How quaint!
Re: Save my sander!
Oh, our tools have motors
they're just cholesterol powered.
