What kind of block plane is this? *LINK*
David Hay Denver
While going through some hand planes I was given, I came across this block plane. It appears to be some kind of double-ended block plane. Anyone know what kind of plane it is? It doesn't appear to have any markings that I can find anywhere. Is it worth keeping? I've already got a nice block plane, so I'd only be keeping it for the bullnose features.
David
More pictures.
Re: What kind of block plane is this? *LINK*
Yep, that's what it is all right *LINK*
You guessed it. Remove the lever cap and cutting iron, turn them around, reinstall, and there y'are: a bullnose block plane. Of course, "reinstall" is a bit more complicated since there's no depth adjustment except your highly refined fingers.
Several manufacturers made these. The notes below are on the Stanley version. I'm no plane expert, but the knob on yours resembles the knobs on some small Millers-Falls planes I've owned; but it could be a Sargent, too, or a Union. Someone more knowledgeable than I am might be along in a minute.
Any numbers cast into the body? That would help to nail down the maker. From there, you could troll completed auctions at eBay to see if you've got a valuable tool on your hands, but I suspect this is unlikely.
Patrick Leach on the Stanley version
Looks like a Sargent
David Miller from Iowa
to me - check the iron for an oval mark. A reasonably scarce plane - Heckel's price guide has it $30 - $60.
I'd keep it (keeping in mind I would keep any plane that wasn't currently in collection)
Jim DeLaney, Austintown, Ohio
Re: Stanley 130 ??
Looks pretty much like the Stanley 130 I have. Handy little plane. Not much value, though, maybe $35.00.
Moses Yoder
Re: not the 131
Moses Yoder
THis is similar to a Stanely #130; if it was like a 131 it would be worth about $200, but the 130 is worth only around $25 or so. The Sargent or Union version that you have might be worth a little more; there should be a logo on the iron if you clean it up gently. The 131 had a depth adjustment that flipped over to both ends of the plane that was a really cool feature.
Joe Rogers, Northern Virginia
I found a Keen Kutter version at a flea. Best $8 I had spent until I found the crack in the side where someone beat on it when I cleaned it. Looks just like mine and Stanley built the KK version. Agree with the advise to carefully clean the iron for actual manufacturer info as that is where the only ID was on mine.
Jr
David Hay Denver
Thanks for the help. I was trying to determine if this is a plane that I would actually use or whether it would just sit on a shelf and gather dust. Maybe I'll hang on to it for a little while and see if I end up using it.
David
They're not uncommon
which implies (though it does not prove beyond doubt*) that they were useful tools. So holding onto it until you determine if it fits in your projects and your working style makes sense.
*Stanley 75s and their clones by other makers are also common, but not, in my judgment, useful, except as paperweights or anchors for model boats.
Stanley 75's also don't skip very well
Bruce, a MN Galoot
when you throw them in the water.
Left out a use
Sir William Duffield used to suggest them to get cats out of the shop, too.
Re: Stanley 75's also don't skip very well
Bob Hackett
If you retract the iron they make decent paper weights.
I can see where some time in the future people will look at how many were around during our generation(based upon E-bay sales records of course) and think they were a valuable and commonly used plane.
Some aspiring Luddites may even attempt to put them to use and their resulting experiences will lead them to conclude we were all nuts and then promptly go back to their atomic powered pocket lasers. :^)
