ADVERTISE HERE - FREE TRIAL
OT: Masonry waterproofer - vapor barrier?
I'm working on the conversion of a slab-on-grade shed into occupied space. It will have 1/2" treated ply laid on the slab, and then floating floor.
The floor surface of the slab is 4" - 12" above a slanted grade.
UGL sells a product that their advertising swears will waterproof masonry. Will such a product serve as a vapor barrier, or should I put down a plastic vapor barrier?
Re: OT: Masonry waterproofer - vapor barrier?
wilbur
I used UGL Drylok on the walls of my cinder block basement. It worked great for preventing moisture from coming through. I could feel the difference in the humidity the day after I put it up.
The limitation with Drylok is that it's not very resistant to wear, so it's not really appropriate for a floor surface. Even if you used Drylok on the slab and covered it with a floor, wherever the floor came into contact with the Drylok, it would wear away eventually, and you've lost your moisture barrier.
So I'd go with the plastic.
Jesper, Denmark
Re: OT:Which side is hot?
Jesper, Denmark
I don't know enough about your climate, but if the living space is heated, the vapor barrier ought to go be tween the ply and some semblence of joists with ventilation under the ply.
I'd use the plastic...
John in NM
As we know a lot of brush on or wipe on finishes are vapor permeable to various degrees - otherwise finished wood would be nice and stable :D
I'm thinking both...
Scott Burr in Ben Lomond CA
Just for the extra protection.
One another note, you might want to look into those epoxy based garage floor coverings, their very tough. I don't know how water proof they are but I would imaging it would be.
