OT: Weather sealing an exterior door
I'm reworking a storage shed, built on slab, into a workshop (my wife's not mine). It's finally getting a decent door as part of this.
The patio outside the door is minimally lower than the slab, and the door's on the weather side to make it worse. The jamb for the prehung door I bought rests on the endgrain of the jambs, and I want to make this as durable as possible and minimize water infiltration.
I'm contemplating screwing down 1/2" treated ply throughout the shop space and into the door opening, sealed with polyurethane at the door opening, which will give me a little height; painting the jamb (of course); and putting self-adhesive flashing on the endgrain and up the back side of the jamb a little.
I will be putting down a floating floor, resting on top of the padding they recommend. If I put down plywood, my plan is to put down plastic under the ply as a vapor barrier and run it up the walls a bit (walls are open, so I can lap it up to the treated mudsill).
I also have to devise a method of sealing the underside of the aluminum threshold to the slab or plywood; the threshold is an extrusion with fins coming down intermittently across its width, and spaces between. I'm considering adhering some treated wood in the space at the outside of the opening and then caulking the daylights out of it (polyurethane again) as I set it in place.
Are there better methods? Is this workable? Do I need to be concerned about the treated plywood in an occupied space?
Re: OT: Weather sealing an exterior door
Paul Dzioba
Bill,
I would treat the end grain of the jam and the bottom of the door with epoxy or at a minimum with some paint or varnish to prevent wicking of moisture. I would also have the door swing to the outside so water won't get trapped between the sill and the door. Once you put down the plywood I would let it 'outgas' for a while. The padding you put between it and the floating floor is a vapor barrier so I don't believe you should have any problems.
Paul Dzioba
