We value your privacy.
I took this photo of a beam drill at an auction preview today. Came home and looked on eBay and a similar one (with the double arch top) went for good money. I didn�t see a name when I looked it over, but I was rushed as the preview was closing. Can anyone ID the maker on this for me? Thanks, David
Millers Falls made one. They called it a Boring Machine. No.145. It had three gears at the top, two drivers. One was for reversing the drill. The shaft they were on slid back and forth sideways. This action reversed the drill rotation while continuing to turn the cranks in the same direction as when drilling.
Yankee North Bros. was one of Millers Falls strongest competitors. They might have made one also.
In the U.S. - at least in the parts I've traveled in - a post drill is permanently fastened to a post and is the pre-power* equivalent of a drill press. What David pictured is the portable tool version - a vertical framework carrying the boring machinery, with some kind of base (a lot of the pictures I've seen used a board large enough for the mechanic to sit on, thus turning his/her tush into a clamp while permitting efficient use of the arms), mostly used nowadays, and probably when they were new, for timber framing.
*although at least some models were designed to be handcranked or powered, with the power presumably from a lineshaft.
The double arch is similar to the James Swans beam drill designs. But, I think yours is a pretty common non Swan version and a little less valuable. All of the Swans that I have visually ID'd had removable handles that were secured to the horizontal shaft with square headed bolts. Also, some have a little tiny swan in the casting at the center of the arches as I recall, but not all of them. I have a Swan Number 2 (per the stencil on the base) that has the removable handles but no swan in the casting.
The Millers Falls, which are by far the most valuable, if in good shape, have an all metal collapsible superstructure made of steel rods.
I have this drill. It is common and relatively cheap, maybe $100-150 in good shape.The name begins with an "S", I believe( not a Swan, possibly Snelling). I would like to buy the style which has a gear on the base that moves the drill to a new position without the operator having to get up off the beam and drill base. Keep me in mind if you run across one of the gear for position change types.
Snell made boring machines. Here is a link to a site that sells these things. At the bottom of the link is a copy of a catalog with several for sale (probably around 1900). No connection, just found link with Google.
Don`t know about you but for me a boring machine would be a wide belt sander.
Runnin` one of those is about as much fun as watching paint dry.Good thing you have to stop and re-spool to change grits or I`d be off to dreamland. ;^)
