Hinges
Patrick Gibbons
I've always had trouble getting the screws in the center of the holes in installing hinges. Does anyone have any tricks they use to "improve my aim", so to speak. My skill with the awl is sadly lacking.
Hinges
Patrick Gibbons
Gadjets
Jack Guzman from Maine
I use a spring loaded screw centering tool. It has a taper that you place in the hinge hole and a center punch that is held back with a spring. Tap it in and your center point is there.It's a simple gadjet you can get at most hardware stores.---Jack
...also
A phillips head screwdriver also works pretty good as a centering punch. It leaves a cross in the center of the hinge hole.Just drill the center of the cross.---Jack
Vix bits *LINK*
Paul M.
I just use vix bits. They have a self-centering spring mechanism built into the bit. They're cheap, and my set of three has lasted me 20 years so far with no signs of giving out.
Vix bits at Woodcraft
Re: Hinges *LINK*
You can get centering punches and even centering drill bits. The link below is to General Tools' versions of these. There are fancier ones: Starrett makes a centering hammerless punch that Lee Valley sells, at a considerable premium over the General Tools product.
I have to say that I've had mixed luck with the centering punch I picked up years ago - not sure that it's always all that accurate, and you have no control over it once you've put it in place. But your mileage may vary.
What I do is make a very light mark initially; then examine it for centering; then, leaning the awl as needed to push the hole one way or another, make the mark a little heavier; repeat the exam; and, once I'm content, push the awl in good and hard. Not exactly a production method, but it works for me.
You might examine your awl and be confident that the point is centered on the shank; if it's off-center, it will introduce confusion.
This may be another of those skills that benefits from practice. Seems kind of silly to practice poking holes in a piece of wood...still, it is a hand tool, and it depends entirely on your guidance.
Some examples
Re: Hinges
scott grandstaff
I took a "Jiffy" pattern punch and added a ball handle to the end to make it one handed and that works well.
Horror Fright and Salvage sells about the same Vix bits as woodcrook for 75% less
yours Scott
These are what I use...
Scott Burr in Ben Lomond CA
Mine came from Hartville tool for very little cash.
Re: Hinges
scott grandstaff
You know, over the years I can't ever remember -not- being disappointed in Woodcraft. I remember them from when woodworking was only practiced by a few lone hobbyists. Before the "big lasting fad" hit. Before FineWW and before the MWTCA. Back there.
It was Constantine, Craftsman's Wood Service and Woodcraft who were the mail order names then. Woodcraft most definitely bringing up the rear in terms of quality and price. Nothing much has changed since then.
You guys who get to walk into a brick and mortar store and negotiate with the owner? Might have a different take though.
But, I like the Lee Boys currently. Best in the mail order biz. Consistent quality and decent price. And I live by grace of mail order.
Speaking of grace...............
They just had a free shipping special and I was broke the whole time it was on!! ... and I need a few cheap small things that postage would kill for me. Sure would love a little extension poverty grace for those "still rounding up the change".
yours Scott
Re: Hinges
Stephen Shepherd
I use a brace and bit for this procedure, first with a countersink that centers in the hole, if you are worried about dulling the countersink, use one intended for metal [old flat ones] or the ones for brass, the rose-head countersink, I just carefully use a snail and it makes the proper taper for the underside of the screw and gives a starting point for the drill.
I use a gimblet point bit the proper size or more commonly a brad awl to worry a hole in the center. The awl doesn't remove wood like a drill, which I think is a good thing to grip the screw as the wood swells back up around the threads..
Stephen
Me too *LINK*
Wiley Horne--So. Calif.
Even I have not been able to make an off-center hole with these. Tap it once, then drill. You can feel when the drill bit sinks into the hole you've made.
Vix bits are fine, too, combining the two operations.
Hey Wiley, a question...
What size screws do those work with?
How small and large in screw sizes that is.
Re: Hey Wiley, a question... *LINK*
Hi Scott,
The centering punch I use most looks like the one I linked at the LV site, but it is marked No. 806, General Hdwe, New York, USA, in three lines.
It has a chamferred section which is 0.33" in diameter. I have a fancier one from LV which has a 5/16" chamferred section, a little smaller.
So what size screw will it center? The max. diameter of a #8 screw is 0.332". See chart below for screw metrics. But that's not the test. Because take a door hinge which is countersunk for say a #10 screw with a head diameter of 0.385". That hinge will be drilled through for a shank diameter which is a lot smaller. A #10 screw diameter is 0.19".
So it's the hinge drilling that controls. As long as the hinge through-drilling is less than 5/16" in diameter, then this type center finder will work.
For practical purposes, this type punch will center any cabinet hinge or door hinge you would find in your house. The only advantage I can see that a centering punch has over a VIX bit, is that one centering punch will work for all screw sizes within reason, and you can use your regular set of drill bits. But for someone doing a lot of hinge setting, a set of VIX bits would save considerable waste motion. One motion and zap you're done.
Thanks Wiley...
So it can't do small hinges using say a #2 through #4 screw, like small piano hinge?
Thanks!
Re: Stear it - the right way
ThomD
What I do it is lay my awl on the side of the hinge hole so it is supported, then shoot for the center. When I hit the center, I stand the awl up and deepen the hole, but not much. Either the hole is centered, or not. If not I next take my drill, probably and egg beater type for this kind of work, and it simply stear it back to center. With the drill bit at a low angle, I start cutting till I reach center, then I stand the drill up and finish the hole. It is a pretty fast method, compared to writing or reading it. It's sensitive, I can easily control what is happening. And I don't use any crutches so I build skill over time.
centering punch
Patrick Gibbons
Went to Sears expecting to find a General. Instead they now carry another brand made in China. Got it home only to find that the hardened striker was not centered in the tube and could not mark a center properly. I am so tired of shoddy goods made in China. I don't know why I didn't just back away in the first place. It's such a false economy to buy a cheaper product that doesn't do the job correctly. I'll find a General and see if it's any different.
