So, I get this package in the mail from Wilbur Pan
David Weaver
And it arrives with two pieces of wood in it. One of them looks pretty innocent - it's the piece of wood that he tortured frank klausz with at the LN event a month or two ago. It's dense, it actually looks like a pretty nice piece of wood, and it's got a thin coat of shellac on one side.
On the other side, it says in pencil something like "work on this side", because he wants to keep the trophy side.
The second piece of wood is a small piece about big enough to make moulding plane wedges, but about 2 feet long. It's quartersawn, I have no idea what it is, but it looks relatively dense in some places, and it appears to grow puffed wheat in between the dense parts - or something about as dense as puffed wheat. What a pain!
I took the relatively innocent piece of wood down to my bench, pulled out my 55 degree infill plane, and took a swipe straight down the quartered grain and the only way the piece of wood could've looked worse would be if it would've exploded - so much for looking innocent.
To make matters worse, the face that I'm not allowed to touch isn't flat, and the side i'm playing on isn't level either
I skewed the plane some since it's quartersawn, and went both directions on it, and it completely refused to be planed.
So, I got out a panel plane to at least level the side that I'm allowed to touch, and did that with much gnashing of teeth. This is now about 5 minutes into planing one goofy little piece of wood..
Got the infill smoother back out and started to work directly across the grain until most of the tearout was out, and then went back down the length askew, and that made it worse again (this is a plane with a mouth < .004"), and it took another full 5 minutes with many drops of sweat falling onto the subject piece until I found a direction that it was remotely close to being cooperative...
pictures to come, and I should be able to mail the package back to wilbur sometime in the near future. I'll let him finish the story when he gets it...
I have to agree with frank klaus (pretty wood, never build anything with it) and admit that i'm beat, though in the end, the embarrassment is not as bad as I thought it would be after the initial pass. It looks sort of like bubinga with closer grain, but I've never had trouble planing bubinga...or cocobolo...or ebony, or anything of the sort.
I wouldn't have believed a piece of wood could've been that bad without planing it myself. Just awful.
Thanks wilbur! Can you tell us what it is?
