Leather for scabards, etc. *LINK*
Phil Joines
This is, with permission, from a Zack White Leather Co, newsletter.
CHROME SALTS IN LEATHER
Have you ever wondered if the leather you have chosen for a particular project contains chrome salts? Many crafters will choose a good vegetable tanned leather for their project, but line it with leather that contains chrome. Chrome salts in leather will tarnish or corrode metal when exposed to moisture, so it is definitely not something you want to line a sheath or holster with.
So, how do you tell if your leather has chrome in it? The majority of leather hides are tanned outside the USA, and chrome tannage is the most popular way to make leather that needs to be durable and strong. A large portion of the leather used for upholstery, shoes, garments and bags is tanned using chrome salts. Many re-tanned leather such as oil tanned and pull-up leathers also have this ingredient used in leather. Latigo, Bridle and Natural Strap are all vegtanned products, but even some of these leathers may contain chrome when re-tanned for particular projects.
So, how do you tell if your leather is safe for exposure to metal? The best way is to burn it. Yes, I said burn it.
Cut a small thin strip of the leather and hold it over a lit match. Let the leather burn and an ash will begin to form at the tip of the burn. If chrome salts are present, the ash will turn a distinct green color once it cools. The color is unmistakably green when chrome is present. If no chrome is present, the ash will be grey in color. This is the quickest and best way to determine if the leather you are using is safe for holsters and sheaths. Remember; If the ash turns green, then do not use the leather for lining your holsters.
-Tim Cox
Copyright � 2002-2010 Zack White Leather Company
809 Moffitt Street, Ramseur, NC 27316 (800) 633-0396
http://www.zackwhite.com/
