Wedged Dovetails ?
Wedged Dovetails ?
Wedged Dovetails ?
Monty Bates
As a lurker on this forum I rarely feel I have anything significant to contribute. However I sometimes purchase some of the British Woodworking magazines which I did today. It is Good Woodworking issue 228. In it there is an article about wedged dovetails. Perhaps I am the only one who has never heard of wedged dovetails but I am wondering if others have seen or heard of this technique? The article hints that it's value may have been in high humidity areas back in the 18th & 19th centuries. Certainly interesting and I can see how it could be used for decorative effects if contrasting woods were used.
Re: Wedged Dovetails ?
Paul M.
The only time I've "wedged" dovetails is when I cut on the wrong side of the line and had to fill in the resulting gap. :D
I would like to see an example of a wedged dovetail, because I just cannot visualize what this is. Are the wedges in the middle of the tails, near the edge of the tails, or in the gaps between tails and pins?
Monty Bates
The wedge is right in the middle of the tails. It seems to be German in origin and crossed the Atlantic into the Philadelphia area and eventually the midwest. It's very difficult to detect when the same wood is used.
Warren in Lancaster, PA
We see wedged dovetails on some period furniture here in Pennsylvania. All that I have seen have the wedge right down the center of the pin. We see it on some drawer pins, tops of slant lid desks and some blanket chests, both walnut and painted poplar. Usually there is a kerf in the pin and the wedge is perhaps 1/16 inch thick. I have taken apart some pieces with these wedges; it might be a little harder to get them apart than just dovetails. It could be some have been used to tighten dovetails that were loose, but apparently most were original construction. I have never seen contrasting woods.
I think I have seen it most (or maybe only) on Pennsylvania Dutch pieces. Pennsylvania Dutch people are a mixture of Swiss, German, French and Dutch, and they also migrated from here to Midwest and Southern states. I don't know where the technique shows up in Europe.
I wonder how they cut the wedges.
Pam Niedermayer - Austin, TX
Stephen Shepherd
Even out in the dry West
Stephen Shepherd
Wedged dovetails appear on a number of pieces manufactured in the 1850-60's made of pine and usually painted and grained. The dovetails on the drawers are not painted as the paint only appeared on the money side.
Also chests, bureaus [chest of drawers], desks and tools have dovetails enhanced with wedges.
The wedges are made of similar wood, no attempt at contrast and are put in a split made with a chisel, no evidence of a saw kerf.
Stephen
