Hide glue for thick veneers
Paul M.
I didn't want to hijack the other hide glue thread, so I'll start my own.
I'm planning on veneering a mahognay desktop that will probably see some abuse. So I don't want to use the typical 1/40" veneer available on the market. I want something thicker.
I'm planning on ripping some good quality Santos or Honduran Mahogany to 3/16" and then planing smooth to about 1/8" to veneer down to a baltic birch substrate. Good quality mahogany is waaaayyy too expensive (over $12 per board foot here in San Diego!) to consider building the desktop out of solid wood, hence this thick veneering approach.
My plan (based upon absolutely no experience) is to coat the substrate and the veneer both in hot hide glue to put a "sizing" on both surfaces and let it cool. Then spray a bit of water on the substrate, lay the thick veneer down on top, and use a hot iron to melt the glue together to "hammer" the veneer down to the substrate.
I doubt that I could ever get large thick veneer onto a large substrate without the hide glue cooling to the point where it doesn't need to be reheated to get it to stick anyways.
Am I crazy to try this? Would a urea/formaldahyde glue or slow set epoxy with a vacuum bag be a better approach? If anyone here has worked with thick veneers before on a large scale, I would like to hear from you. I generally work solid wood and smaller scale, so I'm way out of my league.
Thanks,
-- Paul
Re: Hide glue for thick veneers
Stephen Shepherd
Stephen Shepherd
Paul,
Your plan for sizing both pieces, allowing them to dry then adding water and heat is a very good plan. Works great on thick veneer edge banding as well as laying larger sheets.
What is important is to have a uniform layer of glue on both the substrate and the veneer. A notched glue comb [like a notched mortar trowel] will leave a proper and uniform amount of glue. You will discover that the veneer will curl with the hide glue on one side, so spray the top side with water to ameliorate the problem.
If your shop is 90 degrees Fahrenheit you will have 10 to 18 minutes of open time with hot hide glue, plenty of time to hammer the veneer using the traditional method.
Stephen
Re: Hide glue for thick veneers *LINK*
Paul M.
Thanks for the confirmation Stephen! It's good to know that this is a viable plan. I didn't want to resaw expensive wood just to have a failure on my hands when it came to glue-up.
I saw an article on the Popular Woodworking blog about a veneer failure that has me a bit scared. They claim contact cement is the way to go. I think I'll try my hand at hide glue first since I'm not cutting the veneer thin or on the bias like the failed example in the link below.
The 90 degrees might be hard to come by here, as it's been down in the 60's and drizzling in San Diego. The rest of the country is sweating in 100% humidity and 100 degrees, and I need to put on a jacket. Great bicycling weather, but it's not great for working with hide glue.
Veneer_Gone_Wild
Phil Joines
Just an FYI. Contact cement is the go to method for applying veneers in the custom aircraft interior business. There are at least 4 kinds used depending on the engineering and it's almost always sprayed.
Jack Guzman from Maine
OT:wacky weather
60 in San Diego? That's crazy,it's 90 in Maine. Hit 100 on Tuesday.---Jack
Re: OT:wacky weather
We've been getting longer than usual morning fog here, too; a lot of afternoons when we can't sit outside without coats on.
Our July 4 block party was frigid - everyone had sweaters on.
Slightly cool weather is normal here on the North Coast for July, but not THIS cold.
I'll see your wacky weather
Bruce, a MN Galoot
and oops! You win. That beat us by 15 degrees, although it was 89 in the shop today as I fit panels into frames.
