Progress on workshop organization
wilbur
I thought I'd post an update on my workshop bootstrap process. I have the vast majority of my tools organized and up on the wall, which is a lot better than sitting on the ground in cardboard boxes, which is where they used to be. I'm surprised by how much room was taken by measuring and marking tools. That's pretty much the left third of the wall above the bench -- everything to the left of the chisel rack.
I still haven't made the sliding deadman yet. That's the board sitting on the right side of the bench. I also have pine board cutoffs sitting across the stretchers that will ultimately be a bottom shelf. Those cutoffs are less than an inch longer than they need to be for this purpose. Now that's efficient use of wood. ;)
And before the "time to make a project" chant starts up, I did make a small pencil cup out of cherry scraps that I had. It's nothing fancy -- just 5 sides of a cube, with rabbeted joints at the corners and a groove to hold the bottom piece in. It's on the small shelf just to the left of the chisel rack. Again, I couldn't believe how quickly it went together now that I have a workbench to use.
Re: Progress on workshop organization
Isn't order a wonderful thing?
Bruce, a MN Galoot
Looking really good, Wilbur! Nice pencil holder, too. My pencils reside in two tin cans, so I think you've raised the bar :D
Bruce, Not quite so ordered in MN
My Goodness, Wilbur!
Hank Knight
That's coming right along. It looks great. So does your bench. Isn't it nice to have a place for your tools? Beats spending half your work time looking for them. I'm in the middle pf putting in a cyclone and my shop is in TOTAL disarray. It's driving me nuts. I can't find anything. I'm envious. :(
Hank
Dominic in Bucks County PA
Wilbur,
way to go buddy!!! Your shop looks very cool. As you've said, organization is a beautiful thing. It's almost like it's beckoning you to work in/with it
WOW ! . . .
steve mackay
That planking on the wall looks GREAT ! And outlets, outlets, outlets !
Lovely
you're welcome to stop out and reorganize my shop anytime, Wilbur.
Nice wall, Wilbur!
Stuart Hough
gives me an idea for mine! Bench looks great there, too!
Jesper, Denmark
Jesper, Denmark
I really like the idea of the horizintal storage of the chisels - but do you have any concern over the endgrain strength?
Stephen Shepherd
Looking Good Wilbur
Stephen Shepherd
Glad to see that bottle of liquid hide glue. The bench and wall rack is nice too.
Stephen
wilbur
Hi Jesper,
I'm not really concerned over the endgrain strength of my chisel rack. I cut the pins from a 1/4" oak rod from the borg, and it only needs to be strong enough to hold a chisel. ;)
One other detail that you can't see from the picture: the pins are all tilted up slightly, so that they are a few degrees up from being perfectly horizontal. This way when the chisel is on the pins it settles right up against the vertical piece.
Larry Wyatt
Looks absolutely fantastic, Wilbur!!!
Pam Niedermayer - Austin, TX
Looks good and functional; but... you can't buy any more chisels or Japanese planes, probably some other tool types either. What do you plan to do if you start carving? :)
Pam
Look'n good!
Marv
Looks great Wilbur, but do I see a small gap between the leg on the right where it meets the underside of the bench top?
Marv
PS..."jist kid'n" :D
Jim in Burlington Ont.
Did you sharpen all your tools
Personally I sweep the floor and sharpen the tools. Organization is not my strong suit. You get more shop time if you have to search for a few tools now and then.
Jesper, Denmark
Re: Duhhhh....I should have realized....
Jesper, Denmark
..that real galoots would make the support pins, and not just make saw cuts in a straight board.
My apologies, but it is not easy to see in the pic.
Anyway, got the good answer and will use it for a chisel rack mesself now.
Now, you did not dovetail them, right?
Chisel rack detail
wilbur
Just in case you were curious. The vertical pieces are 1x3 pine strips that I got from the borg, and after putting in the 1/4" oak dowels, they are mounted separately to the wall. The two pieces of the rack are not attached to each other, just to the wall. This picture shows how the slight upward angle of each dowel causes the chisel to nestle right up against the wall.
You can also see the hand tool purist screw that I used to attach the vertical piece to the wall. ;)
Carving tools
wilbur
If I start acquiring carving tools, I'll build a box to hold them, using my new workbench. ;)
Yeah, but I bet...
Kevin Adams
you used that liquid hide glue for the oak dowels! :)
Looks really nice, Wilbur. I wish I had used the pine boards on my wall instead of the white peg board. I'm down in the basement, too, so was trying to brighten it up with the white, but the pine makes it look so much warmer and like a hand tool sanctuary!
Btw, about 3 more weeks and I'm back at HITWGC, too...hope our weather cools off a wee bit, but can't wait to get back there. Did you enjoy your week?
Take care,
Kevin
Jesper, Denmark
Re: Chisel rack detail
Jesper, Denmark
Great Wilbur,
But you could have hidden the manual Hitachi screwdriver in the bottom left of the first pic. ;)
Incidentally
In the first picture, it appears that you're using a fairly small-diameter dowel for the strut on the bottom of your leg vise - is that right?
I've bent a 20d nail with my leg vise; you may find that you need something more substantial, if you are indeed using a dowel.
Re: Incidentally
wilbur
It's a 3/8" oak dowel that I got at the borg. I've had no problems whatsoever so far, and I've been really cranking down on my vise.
Put it this way: I was planning on using the dowel temporarily until I could get a nice piece of 3/8" brass rod and make a fancy cherry handle for it. That project is now very low on the priority list.
I sit corrected
Maybe I need to consider a dowel when I reassemble my granddad's leg vise, down the road a piece.
