Re: Sideboard-Entertainment Centre: Building the f
I think that you probably should miter the corners. In my late night perusing I forgot that it was an entertainment center, thus tall. How tall?
Hi Pam
Thanks for your input. This is very much welcomed.
I like your idea of a mitered corners. In fact I am prepared to make another (I think I only need one) new rail to accommodate the mitred corners. My only concern is whether it will be strong enough. Are mitred corners, with the reduced mortice area, as strong as traditional, squared m+t joints?
For reference, the units are (in total) 700mm (approx 27 1/2") high, including the feet (about 50mm/2" high) and the top (about 20mm/ 3/4" thick). That leaves doors 660mm/26" high.
