200+ woodworking book reviews
Leather Hand Saw Covers
Larry Wyatt
My wonderful mother-in-law(an accomplished seamstress) has agreed to make me some leather covers for the blades of my high-end hand saws. I know I've seen them. Generally suede with a flip top and a couple of snaps to keep it in place.
A google search has been fruitless.
Can anyone point me in the right direction to pictures or patterns?
Thanks a bunch!
Larry Wyatt
aka Cole's Dad
Re: Leather Hand Saw Covers
Hi Larry
I am curious to why you might want these? Personally I would find covers a nuisance.
I can understand if you travel with your saws, or plan to transport them regularly. But for storage in a shop, well I can think of better methods .. safer methods.
A saw till seems to be more appropriate for storing saws (this is how I store all mine). Edges are protected by keeping them from touching other steel. The wooden cabinet tends to inhibit rust, and this may be taken a step further with a light rub of wax.
If you live with humidity, then cancass seems to me to be better protection than leather, which may be the type that was cured with chemicals which actually promote rust. I would check your leather/suade out carefully before using it.
I think that LN sell saw covers for their saws.
Wiley Horne--So. Calif.
Hi Larry,
Here is the Lie Nielsen link Derek was talking about:
http://www.lie-nielsen.com/catalog.php?grp=1217
Your mother in law would be able to make her own pattern, if shown the basic idea (from the photos) plus the saw(s) for fitting.
I believe you may be in one of our national rust zones, and if so, might benefit from 'rust proofing' paper. It turns out that there is one manufacturer of this type of paper in the US, Cromwell Phoenix in IL, and LN carries their product as well:
http://www.lie-nielsen.com/catalog.php?sku=Ferro-Pak
My best Japanese saws always come wrapped in this type paper (brand name 'FerroBrite') and it works.
Another option from Lee Valley:
http://www.leevalley.com/en/wood/page.aspx?p=58755&cat=1,43326
Wiley
Be sure you have the right leather
Bob Hackett
Most leather has been tanned with acid and this will just promote corrosion of both the iron and brass components of the saws.
What you would want to use is a vegetable tanned leather.Ask around where knife makers get their material to make sheaths.
Moses Yoder
Re: how to make a tool rust
Moses Yoder
Imagine my surprise when I pulled my brand new LN 101 plane out of it's leather sheath to find it covered in rust after several months of setting in a tool box without use. I read that leather sheaths will hold moisture, and most knife collectors will not store the knife in the sheath; they set them side by side in a case, only putting the knife in the sheath for traveling. I store the plane out of it's sheath now in my tool box and have no problem with rust on it. A leather cover for a saw would be nice and impressive for traveling, but I think your saws will rust less if you build a saw till with a reasonably tight door out of wood, or just oiled and stored in an open saw till.
Stephen Shepherd
Stephen Shepherd
I would recommend using oil tanned latigo leather.
Stephen
Larry Wyatt
Thanks so much, everyone!!
I'm not traveling with the saws. I currently have them in an open till and they're getting spots on them from the humidity. I want to keep them as pristine as I can, so I need another option.
From your comments, it seems as though I have two viable options; the leather that Stephen spoke of or a closed saw till.
Thanks again!!
Larry
Dominic in Bucks County PA
Re: Yo Dom, you out there!?!
I used a Goldenrod dehumidifier. But as stated, you need an enclosed cabinet.
Wood box and dessicant
John in NM
or something similar. If its humid enough there to spot on its own, packing it in leather probably won't help. If you really want to try the leather, I'd start with straight vegetable tanned leather - basically just that light colored cowhide they use for saddlery and straps - then treat it with melted beeswax. No oil. I've seen the entire item immersed in melted wax (be careful not to deep fry it), or the wax applied with a detail iron, like they use for stretching skins on RC airplanes. Sheaths and stuff I've done this way haven't had any tendency to rust the contents, but then its so dry out here that this wouldn't be a problem anyhow. So your mileage may vary.
