Darkening Walnut...
Darkening Walnut...
Darkening Walnut...
Scott Burr in Ben Lomond CA
Hi All, I'm finishing up on a reproduction of John Hall's picture frame. The walnut I had is a little light for me. Any good way to go about darkening it?
It doesn't like dk. walnut stain, it can't seem to penetrate the wood.
Re: Darkening Walnut...
Moses Yoder
Moses Yoder
Do you have spray equipment? Would make a diference in application. A seal coat would be applied first, and then sanded lightly then a coat of stain sprayed over the sealer to darken it. This is called a toner coat. Another option would be to buy a pint of glaze and wipe it on the seal coat. Glaze can be easily applied with a brush then wiped with a rag. Glaze is applied thick and then wiped off to the desired thickness of application. Glaze will not darken it as much as a toner but will darken it some and and also has the effect of catching in any ridges in the woodwork and moldings and accenting the shadow lines. Glaze is available in various colors.
Paul Dzioba
1. Did you sand with very fine sandpaper? You might have burnished the wood enough so that it won�t take stain. If so lightly sand with 180 grit and see if that helps.
2. Try an aniline dye.
3. Try fuming with ammonia. Walnut is one of the woods that have a high tannin content, the chemical that turns oak dark when you fume it.
4. Most important� TRY THESE ON SCRAP WOOD. I always do a test on my cut-off scrap when trying something new.
Paul Dzioba
Marv
Hi Scott,
Try some leather dye or shoe dye. I use the Lincoln brand. Try to not get any on your fingers or you'll be stained for life.
Dark Brown might do it, if not, use Black.
Use clear Lacquer for a finish coat.
Marv
Dominic in Buck's County PA
Do you want it black, or just darker?
If black, I suggest a ebonizing solution. Steel wool soaked overnight in vinegar is what I've used before. Just strain it before you apply it.
The handles to the left were ebonized walnut.
And testing it out on a piece of scrap is ALWAYS a good idea.
Van Dyke crystals...
Tony - Memphis
Basically, it's a natural stain made from walnut husks/shells? or something like that. I use the Lockwood brand. I use this to match some sapwood with heartwood. I built a lowboy a while back and had good luck with this (a few boards had soem light areas that I blended in). It is water based and you can mix it to the strength you like. I followed with an amber glaze to get the "warmth" I was looking for. I actually got it too dark, but that's ok. My shop is very bright, but my dining room isn't!
Tony
JIM O'NEAL
Check out the Charles Neil 6 disk DVD set "It's All About the Color". He has a very informative section on coloring walnut along with cherry, oak, maple and poplar.
Hi Moses, I have no spray equipment.
What exactly is a glaze? I could never quite figure that out.
Thanks Paul!
I'll ALWAYS practice on scraps :D
I'll try roughing up a scrap a bit and re-stain to see what happens. I have some high strength ammonia as well so I'll fume a scrap as well.
Thanks again!
Walnut is a complicated color
Old walnut has golden and reddish highlights, so restorers and refinishers often "shock" the cool brown of fresh walnut with an ocher-colored dye stain, followed by a reddish dye stain, before finishing up with a final brown dye. Note that I mention dyes and not pigment stains. Pigment stains (like the "Dark Walnut" you mention? Minwax maybe?) accentuate the pore structure by leaving dark pigments in the open grain areas, but the vehicle (which may contain some dye depending on the color) may or may not significantly darken the harder wood tissue, particularly the summerwood of hardwood species.
If you just want a darker brown, you might like a dye or NGR stain called VanDyke Brown. You won't get the color complexity I mentioned, but it will be a neutral brown-brown, as opposed to reddish brown. Glaze is just a thick pigment stain, practically paint, that you brush on after coloring and then wipe off selectively to create an aged appearance, fill the pores with pigment and darken the wood somewhat. You might try using it by itself and see if the effect appeals to you.
Ellis Walentine, Host
Re: Van Dyke crystals...
Tony - Memphis
Here is a couple of pics. Be sure to consider that the light in these two pictures is very different. My shop has flourescent tubes (cheapies) and the house had sunlight and incans.
This is the top in the shop...
This is in the house...the amber color is much ore obvious. the sunlight seemed to realy hi-lite the amber. My glaze was made with wipe on gel poly and Trans Tint dye (Honey Amber maybe?)
I was really pleased with how well I was able to match colors. I didn't have any super contrasts, but enough that they needed to be addressed. I haven't used a bunch of walnut, but I understand its something you have to work with (the color variation that is).
Tony
Re: Walnut is a complicated color
James Watriss
I've used similar treatments on Cherry... Honey amber trans tint followed by some Garnet shellac.
My personal recommendation would be a light treatment with the aniline dye, followed by (and this is where the test pieces come in handy) a dyed shellac. Since aniline dyes (I use transtint, it's more colorfast) are soluble in alcohol... and so is shellac... you can fine tune the color of the finish to fit your liking.
Best black finish I ever got on Maple was done this way. Aniline dye on the maple, followed by a french polish with a dyed garnet shellac. The black base color, followed by the blackened finish, mellowed by the garnet color of the shellac, was just incredible.
Re: Just darker...
R Payne
Linseed oil will darken walnut. More coats means darker to a point.
ron
Thanks Ellis
Yes, I tried Minwax dark walnut, had some laying around. So does one buy or make glaze?
I have not used Walnut all that much, and what I've mostly used was Claro recovered from orchards in the central valley. Looked great without all this fuss.
This stuff came from a local hardwood supplier, that's why I'm full of questions.
BTW, you ever do anything the the Millers Patent Plane from Paul?
Thanks for your help everyone, here's round two...
Here's a shot with the flash:
And one without:
I want maintain the some of the contrast in the wood and the curl. Now what does everyone think?
Thanks again!
Re: Thanks for your help everyone, here's round tw
Tony - Memphis
Nice wood..and nice work. I would definitely be careful to try and bring out the curl rather than hide it.
Tony
Moses Yoder
Re: aniline dye
Moses Yoder
I would use a dye stin. The dye will soak in regardless how smooth the wood is because it is still porous. Pigment stains will not have anything to catch on smooth wood plus they will tend to obscure the grain. A glaze is a thick pigment in a syrupy carrier, and will also tend to onscure the grain. I would talk to Jeff Jewitt at Homestead and see what he recommends for dye stain on walnut.
Moses Yoder
Re: aniline dye *LINK*
Moses Yoder
The link below shows Jeff Jewitts aniline dye stains; there is a #3260 dark chocolate brown stain on the second page at the top that would probably look good on your frame.
Homestead Aniline Dye COlors
Miller's Patent Plane
... is in my trophy case. The tolerances between the blades and the V-channel are not accurate enough to make it a user. I enjoy looking at it.
I second that
