Have a question? Ask Woody!
Homemade hand powered grinder?
Edward in Vancouver
The bargain basement 6' grinder crapped out on me today, didn't miss the 36000 rpm, but I do miss having a 6" grinder of some sorts around.
Any plans floating out there to build one out of wood?
If I just rigged soething up with an arbor and and crank, would I need a flywheel of some sorts? Not grinding any heavy stuff, but to put a new bevel on a 3/4" chisel would need some "oomph" and I'm not sure if just hand powered would be enough.
Re: Homemade hand powered grinder?
Re: Homemade hand powered grinder? *LINK*
wilbur
Bob Rozaieski has got your back.
Hand powered grinder
Bob Rozaieski
I don't know about a 6", but I've been working on a 10" x 2" wet grinder using a replacement wheel for a Grizzly Tormek copy. I would think that a 6" would need to turn a lot faster and would need to be geared to do so. Not sure wooden gears would work so well. The Tormek style wheels are made for turning about 90-150 rpm, easily doable with "direct drive". It actually cuts a lot faster than I was expecting and will be just fine for minor bevel grinding to remove small nicks or chips in the edge or re-establish a hollow grind. I'm still keeping my "high speed" 6" hand crank grinder for major rough reshaping though. The wet grinder is too slow for major steel removal.
David Weaver
Bob - I got one of those wheels (assuming that's the $49 one) when someone asked once on WN if there were cheaper wheels for a tormek. I was curious, and decided to try it.
I have to say it was the worst wet wheel I've ever seen. It cut fast, but it fell apart faster. That may not be an issue with a hand crank, because you won't be able to put enough pressure on the wheel to equal what you can on a tormek.
My wheel wasn't close to round, so I trued it with the tormek truing tool. It got promptly out of round again and when I turned the chisel into the stone, each time a dip in the wheel came around, you could hear it digging into the stone and pulling off large amounts of abrasive.
The wet tub under the wheel was filled with loose abrasive, tons of it. I dumped it out, took the wheel off and tried to figure out what I could do with it and eventually just threw it in the trash.
I hope they have improved them since they. They are not up to snuff with the sheppach wheel that comes on the grizzly grinder. At the same time, I think a tormek wheel, which is probably cost prohibitive to most, would also be too hard since it has a ceramic binder.
Maybe the grizzly wheel will work for you since you are presumably turning it away from the tool and using less pressure. I'd hesitate to leave it sitting in water for any period of time, though.
I'm guessing yours came in a box that said "CHINA" on it, and maybe with a grizzly sticker on the top, and feels very coarse compared to a tormek wheel.
Bob Rozaieski
Well, I've never even seen an actual Tormek wheel in person, much less used one, so I can't compare the Grizzly wheel to the Tormek wheel. But it seems to be working ok so far. I made the water trough removable so I can empty it each time I'm done using the grinder and let the wheel dry. I wouldn't let it sit in the water. I turn it toward the tool rest just like any other grinder and it seems to be working fine so far. The tool does not dig into the wheel. I don't apply a lot of pressure to the wheel, but I don't feel the need to. It does what I want it to in an acceptable amount of time just holding the tool to the wheel hard enough to keep it from being pushed back up the tool rest. Took me 4 or 5 minutes completely regrind the bevel on a 3/4" chisel the other night, but I don't expect to have to do this very often with this grinder. Its main use will be for re-establishing a hollow grind, which should take no more than a minute or two. The wheel wasn't perfectly true when I got it but a minute with a diamond wheel dresser took care of that. Time will tell how well it holds up, but I'm satisfied with it for $50.
Thomd
LV used to sell 800 grit waterstone wheels for their big wheel grinder, they don't sell the grinders any more, but they might sell the wheels...
I would want more speed than you can get with an ungeared hand crank. I picked up a geared one like the one in Krenov's book for 25 bucks a while back. I was interested to see that the typical wheel in a cabinet shop was something like 4 foot in diameter, for hand turning. That makes sense to me, but obviously wouldn't make sense to find or own. Even back in the 19th century, they were lauding the steam powered wheels, if you could get one. All this from CS's latest book.
If I had a little space, and was wanting a non-electric wheel, I would search out an old singer base on KIJIJI, or craigs. The work great and while people ask all sorts of prices for them they show up for 20 bucks -40 bucks periodically. The treadle is really well designed and will develop some speed.
That said, I can't really see beating the taiwanese 8" grinder at 1800 rpm, on price or performance.
I do have a basically NOS LV grinder I want to sell when I get back home in September.
David Weaver
Bob - given the origin of the wheel, and its unknown consistency, it's entirely possible that the one I got was junk and the one you got will be fine.
It is also possible that it'll hold up fine because of the way you're using it, and I agree, it should cut a hollow very quickly, even with hand power. I would almost wonder if it was better to use it dry given how aggressive and soft it is. I had the troubles with mine trying to run a little off a new iron, which is something I always do if I have the time. It would've been wiser to blunt it with a dry grinder and then work most of the way back to the edge and then go to the wet grinder.
The difference between it and a tormek wheel is that a tormek has a hard binder and you could wear the aggressiveness off the abrasive before the binder lets it go, while I don't see that being nearly as much of an issue with the wheel you've got - at least not if its similar to mine.
I have a dry grinder that wobbles the way you describe with a wet grinder. I have to have it clamped to its base or it'll walk. But, having the tormek, I don't have a great need for it to be in existence other than that I like to have my hands in a lot of cookie jars, and as an aside, I like the geometry of the hollow from a 6" wheel. I think your grinder plan is good for maintenance sharpening, and wouldn't be afraid to copy it if I didn't already have too many duplicates of it already.
