need ideas for shop
need ideas for shop
need ideas for shop
Roy Anderson
I'm moving to a new house with a three car garage. We specifically got the three car garage so I can make my shop out of the third bay. Now I have to figure out a way to divide the garage to separate my shop.
I don't want to build a stud wall. I'm thinking about just building a lot of cabinets that reach from floor to ceiling. One co-worker suggested an accordion wall that I could pull back or maybe make the tall cabinets on rollers so they could be moved out of the way.
I'm looking for more suggestions. Any help appreciated.
Re: need ideas for shop
Jack Guzman from Maine
How about installing upright posts from floor to ceiling 3 or 4 feet apart? You can put pegboard between some of them. Cabinets,floor or wall style. Hang a screen between them,or whatever.You could even leave it open between them with a short railing to separate your shop from the cars. I did something similar in my shop using old barn timbers. Lots of places to hang stuff. Also the area between the posts can be changed from time to time. ---Jack
scott grandstaff
scott grandstaff
No problem with this at all, and congratulations!!!
Get a carport for the cars. You know you will eventually anyway. ;)
yours Scott
If you build cabinets
You might think about making them double-sided - cabinets on each side, even if they have to be a little shallower. The most accessible portion of a cabinet, nearest your hands when you open the doors, is always the most useful.
Re: need ideas for shop *LINK*
Paul M.
Hi Roy,
A 3-car garage was my only requirement on our latest house. My wife gets the entire house, but I get the 3-car garage. She gets to park her car in one of the 2-car bay spots, but all of the household stuff belongs in the house so that the garage doesn't become the houshold storage area. That was the best bargain I ever made.
Does your garage have roll-up doors? I've found that the railings for the doors between the 2-car bay and the 1-car bay make excellent long sheet good storage. My plywood gets ripped to 24" wide at the lumberyard ('cause my truck is too small to safely get full sheets home), and then I can store it vertically between the rails so that it takes up little space.
I have a solid wood storage rack down low on the ground inside the 1-car bay, which is about 30" x 30" and 8 ft long. You can stuff a lot of lumber into this 30x30 area by sliding it on it's sides through this long tube of storage. This is the anchor of my separation wall which is just 2x4s bolted to the lumber storage unit at the bottom and to the ceiling at the top. These are about 30" apart, so that I can get my 24" wide sheet goods between each of the 2x4s.
I also added a heavy duty shelf rack to these 2x4s so that I can make shelves for storage above the wood rack. I didn't want cabinets, as I didn't want to wall off all the light. The link below is the storage shelves I used as they can take quite a load.
I also have an accordian door made of plywood that encloses the gap between the 1-car bay and the 2-car bay. My dad had an old decrepit cat that lived in his garage for years until my dad died. We took the cat in and put him in our garage. I made the accordian separator to keep the cat in the 1-car bay where he lived happily for a few more years. The accordian door is still useful, so I've kept it there.
I've found that this 1-car bay has become a bit claustrophobic to work in though. I keep my grinder, bandsaw, and dust collecter in this section now, and work primarily at my bench which is against the back wall of the garage in the 2-car bay.
I hope this helps. Let me know if you need pictures of any of this.
-- Paul M.
Storage shelves from Lee Valley
