Veritas Scraper Shave Review
Larry Wyatt
For whatever reason, having seen pictures of scraper shaves, I have recently become almost obsessed with having one. I know none of y'all have any tools obsessions, so I'll just admit mine as the first part of my 12-step program from OTCA(Obsessive Tool Collectors Anonymous).
Having received the Veritas scraper shave the other day, I thought I would detail my experiences with it so far and post a short review.
I knew this tool was hefty as soon as I lifted the box. It carries some substantial weight, which I believe helps with its use.
Out of the box, the shave was in excellent condition. After taking it apart to use some mineral spirits to remove the anti-rust coating, I checked the machined surfaces and they are quite flat. Machining tool marks are still visible, but using this tool is not micrometer level woodworking so flat to a straightedge is fine. This tool fit the bill very well.
After cleaning the 'blade,' I honed the back on a fine ceramic stone to remove the scratches from milling. I didn't bother with the bevel though. It's *very* tiny and I wasn't in the mood to try and balance it or make a jig. In the long run, I don't think it makes a difference in performance from my perspective.
I then turned a small burr at 15 degrees towards the non-beveled edge.
Then, it was on to waxing all the bearing surfaces to help the tool glide. I also waxed the machined surfaces to hold off the rust.
The blade is placed in the shave with the bevel away from the front brass. Push down on the blade and tighten the knobs and you're ready to test it.
I found I needed to use a small wooden mallet to tap the blade into the correct position with appropriate parallel blade reveal. It took a couple of tries, but was fairly easy. If the blade is not parallel, the mouth clogs very easily, so proper set-up is important to avoid such frustration.
Now on to use.... When I first used the tool, I did what any good scraper user would do. I pulled it towards me with the tool tilted forward. HEY! It's not cutting!! Oh, wait a sec, this isn't free form scraping with a hand scraper! LOL Anyway, it's important that you reference the bottom of the tool to the workpiece. The small footprint of the shave makes it imperative that you 'wiggle' it into flatness on the board on which you're working.
It works *very* well, when positioned correctly, as you can see in the photo. Nice whispy shavings. It does take a bit of downward pressure when scraping, but that's true of any scraper. It even works well on the edges of board to create a minute chamfer or roundover.
Only one negative that I can see so far and that is that this tool chatters like crazy when I push it. Now, that may be operator error and I suspect that it is. But pulling it removed the chatter marks, so no big loss. :b
Conclusions:
The fit and finish of this tool is exceptional, as one would expect from Veritas. Set up is easy and the tool performs beautifully for its intended purposes. Mind you, you can't(and probably shouldn't) try to scrape a large surface, but that's what large scrapers and the Veritas Scraper Plane(which I also own) are for.
The Veritas Scraper Shave is a bit expensive, but quality tools are. I'm going to try fashioning a homemade one as suggested by many of you. That way I'll have something to compare it too.
Larry Wyatt
aka Cole's Dad
Houston, TX
Re: Veritas Scraper Shave Review
Thanks and one comment...well, two
Thanks for the review.
You said, "...this tool chatters like crazy when I push it..." I have noticed with spokeshaves, especially round soled shaves, that I get distinctly better performance by pulling them. I think it has to do with body mechanics - our wrists curl forward better than backward, and the intuitive adjustments needed to avoid chattering are easier when you're flexing toward you. That, anyway, is my hypothesis.
Final comment: just when I thought I had my lust list under control, you have to go do something like this. Thanks a lot :)
Re: Thanks and one comment...well, two
Larry Wyatt
I'm adopting that theory, Bill. That's mah story and I'm stickin' to it!
Welcome to the OTCA. Say it with me, "I am an obsessive tool collector." ;)
Larry
Not obsessive
Bob Hackett
But I know where the line is and have been known to "Hang ten" a few times.
MB-Swimming in de-Nile and hoping the crocs don`t get him. :D
