Re: OK, I have to ask...
"The 14� marker is designed to approximate a 1:4 ratio, for those who prefer this angle when working in thinner stock, as it not only provides stronger material interlock than traditional ratio angles but produces a slightly exaggerated dovetail joint that many find attractive."
Hi Tom
A 14 degree marker is VERY different to a 14:1 marker. The ratio is calculated on a grid by marking 14 points (e.g. 14") vertically and 1 point (e.g. 1") at a right angle.
The angle so created is the angle of the dovetail.
Typical ratios are 8:1, 7:1, 6:1 and 5:1 These are chosen according to the thickness of the wood (lower ratios look better on thinner board because the dovetail ends up smaller), hardness of the wood (higher ratios are better the harder the wood), and just plane aesthetics (it really comes down what looks best to your eye as modern glues rule). A 4:1 (or 1:4 depending how spatially challenged one is) will create a very wide dovetail.
Here are examples of rations from 5-, 6-, 7-, and 8:1
A tutorial here for the above: http://www.inthewoodshop.com/ShopMadeTools/Dovetailmarkersinbrass.html
For most drawer sides, roughly about 3/8" thick boards, I tend towards a 7:1 ratio. My favourite (shopmade) dovetail marker (its a joke .. dovetailed dovetail marker
