A CPM3V Chisel
Dominic in Buck's County PA
Hi Gang,
I was lucky enough to get one of John ("jcav8ter" on WoodNet) Payne's prototype CPM 3V chisels to try out. This one is a 1/2" bevel edge chisel. Normally they come "fully assembled", but John knows I love to tinker and sent me the raw materials to build my own.
I turned the new coccobolo handle last night. The ferrule was fitted to the tenon and then epoxied in place with Loctite's 5 Minute 2 part Epoxy. I used a LN handle as a template then made it a bit longer so it will work better as a parring chisel.
After sanding I gave then handle several coats of sealer. Today I sanded it one more time and then gave it several coats of blond shellac buffed out with 0000 steel wool.
I used 45 micron diamond paste to flatten the back. It went a lot faster than I had expected. I thought I'd be at it all night. But it took only a bit longer than a "standard" chisel did. After flattening I polished the back to a mirror finish.
The blade got hollow ground on my grinder and then sharpened using 220 grit sandpaper (to establish the bevel) and the 1000, 5000, & 8000 Japanese Super stones. I then honed with Veritas Green Honing compound on MDF. It is DAMN sharp.
Here it is next to a similarly sized LN chisel. Like I mentioned above, I made it longer to help me use this as a parring chisel.
BTW, the blade was epoxied it in place using the same stuff I used on the ferrule. After it set, I was able to parr end grain pine with no problems.
Overall I'm pretty happy with the outcome. If any of you are hesitant about getting these chisels because you think they'll be hard to sharpen, don't worry. I could handle them pretty easily. You just have to expect it'll take a bit longer to get the edge going. After all, it IS harder steel.
Anyway, I look forward to actually using it on a project and will report back as soon as I have more data on it's edge retention.
See ya around,
Dominic
