Bow saw JR.
Bow saw JR.
Bow saw JR.
Andy Lincoln,in Dearborn MI
Well I went ahead and milled out the parts to build the smaller scale bow saw as mentioned in my earlier post.It wasn't exactly half scale but I sized the original down to handle a standard 6 1/2" coping saw blade.
I didn't size the handles down too much as a feared they would be too small to grip and too weak for the pins.
This time around I decided to make my own pins from a couple 1/4-20 bolts,instead of ordering from TFWW,as I wasn't sure this would work.So after a couple hacksaw blades, several Dremel cut-off wheels and a few curse words I had the pins cut.My next challenge was the bolsters/stops/washers that were on the original brass pins.My idea of the moment was to solder a #10 flat washer onto the shank of the bolt.I presume that the washer is there to prevent the pins from pulling out of the handles through the arms of the saw. I couldn't find anything definitive on the internet or You-tube as to soldering steel but it seems to have worked/held.The pins were then epoxied into the Beech handles.
I then did a quick assembly and realized a big oops! I had laid out the pins based on them being full size,not taking into account that the width of the arm was different.Now I had a few choices ,one was to cut and re mill the pins,another choice would be to make the stretcher longer,but I found a quicker,easier method ,hence the two aluminum spacers on either side of the arms.They worked very well right out of the parts bin and in 30 seconds I was back to having a working Bow saw Jr.
The next one may be a bit more refined,but I know the concept is sound.
Thanks,
Andy
Re: Bow saw JR.
Nifty
and easy to find blades for.
Re: Bow saw JR.
Nice saw and a sweet fix, I mean...
Scott Burr in Ben Lomond CA
Feature, yea that's it, the spacers there as a design element. Yea, that's the ticket!
Great saw!
