Built a Bowsaw
Built a Bowsaw
Built a Bowsaw
Andy Lincoln,in Dearborn MI
Hi All,
While I was waiting for some other work in the shop to dry and when I could sneak a few minutes in I was able to build a bow saw from the plans at Gramercy Tools Turning Saw Parts.
I used Beech as I have a good amount of it and absolutely no hickory as was suggested in the plans.
I ordered the kit with the blades and pins.I was able to get my very first (working) l@the over the last weekend which then allowed me to turn the handles.having no experience with turning I waited to place my order with TFWW until I had the handles completed to my satisfaction as they offer a kit with handles included,as well.And I happen to think I did a great job on the handles for my first ever turnings.
The parts came today(ordered on Tuesday!!) via the USPS so while my truck was up on blocks and the oil was draining I was able to put all the components together.I used Devcon 5 min epoxy to install the pins into the Beech handles.I was too excited to wait for West Systems epoxy or poly glue to set up.Time will tell if it will be of sufficient strength.
I went to a local tackle store and bought some 30 lb. test fishing line to use as the tensioning mechanism.I now have enough of that line to make a lifetime supply of bowsaws.
When I downloaded the plans as a PDF I was able to use CAD software to create a pattern for the pieces out of polycarbonate which I cut extremely quick and accurate on a waterjet.I was also able to
re-size the parts to fit a standard 6in coping saw blade but as of yet I did not begin to mill out the junior version.
The finish is a blend of BLO, Turpentine and Poly,which seems to be my go to shop finish.
Thanks for looking ,
Andy
Re: Built a Bowsaw
Re: Built a Bowsaw
Very nice, and I'm awed that those handles are your first turning work.
Making the handles different one from the other was an intelligent move, so you can tell quickly which one to grab in picking it up.
Re: Built a Bowsaw
Built a Bowsaw, and a nice looking one too!
Scott Burr in Ben Lomond CA
One (or more) of these have been on my to do list for a long time. I recently got a lathe as well. I have no experience in turning what so ever. I have a few questions if you don't mind.
How hard was it to turn the handles?
What tools did you use to turn them?
What speed(s) did you use?
Scott, hoping one day it will be my turn to turn some bowsaw handles.
Re: Built a Bowsaw
David Barnett
Very nice
David Barnett
I've got a very old bowsaw with handles similar to those. My smaller one may be a bit rounder. Fishing line looks like it'll work nicely although I prefer my cord made from #7 post-mortem linen for conversational chachet.
Re: Built a Bowsaw
Re: Built a Bowsaw
Bill,
Thanks for the kind words but I cannot claim that it was my idea.
The different handles were a result of following the PLAN
I have never been known for being creative,but I can usually follow a simple drawing.The folks at TFWW made this project a breeze.Here is a link to their Design Considerations
Not only were the drawings/instructions/tips great the parts they provided were top notch.
Andy
Re: Built a Bowsaw
Re: Built a Bowsaw, and a nice looking one too!
Scott,
I found the Beech was very easy to turn.I used a gouge ,a parting tool ,a round nosed scraper and a beading tool.
Along time ago at HF I bought a set of lathe tools for +/-$30 ,these were what I used direct from the box,as sharpening them/regrinding them has not yet been attempted.I have no idea where to begin on that front.
I did have to saw the handles free from a larger block as I couldn't figure out how to hold the pieces after the majority of the turning was done,or how not to hit the spinning spur,live/cup center with the tooling.I did have to sand the ends to become rounded.I am sure with the right skills and/or equipment(chuck,etc) It could be completed right on the lathe...but not with my skillset.
Currently my late,a Delta MIDI Lathe is set to spin at 800 rpms not the slowest setting but far removed from the fastest.
I did sand most of the turnings while on the lathe but did the finish off the lathe as I had to sand the ends and drill the holes for the pins.
I used a caliper to transfer the major dimensions and worked the shape from there using the plan as a guide to coordinate my hands and eyes.Is it exact?No way...Does it work? Yep!!
I cannot recommend my training philosophy of it is only a small block of wood,how bad could it hurt?But being stubborn as well as excited to finally own a lathe I chose to jump into the pool.I did watch a couple You-Tube videos( How funny is that.." I don't need to go to college,everything I need to know I can learn on You-Tube",I can hear my 13 year old using that line) trying to pick up the basics before introducing a stationary tool to spinning wood.
I also purchased a face shield and had on a LV tool apron before I attempted to turn anything.Not that it would make me bulletproof, but I was attempting to be as safe as possible.
I hope this helps in some way,
Andy
Re: Built a Bowsaw
Re: Built a Bowsaw
Dominic in Buck's County PA
Very nice work Andy! And the handle looks pretty darn cool!
Well done!
Re: Built a Bowsaw
Jack Guzman from Maine
Re: Built a Bowsaw
Great job and a good looking tool Andy. I built one a few years ago and I find it handy. It's a good size. Joel did a good job putting together those kits and plans. It's a good resource.---Jack
Re: Built a Bowsaw
Nicely done!!!!
Larry Wyatt
Re: Built a Bowsaw
Re: Built a Bowsaw
Stuart Hough
You are the tool-god! All the woodworking goodies, a new lathe, AND you've got a waterjet?!?!? You're my hero! What else is behind the door?
Re: Built a Bowsaw
David, if you and Todd Hughes ever join forces...
Re: Built a Bowsaw
Thanks Andy! *LINK*
It's sounds like your learning a lot like me :D Wadda ya mean, you-tube is a great college!
I bought some Doug Thompson lathe tools and they are unhandled. Guess I should buy one or two with handles so I have a pattern and a starting point.
Thanks for the info on speeds and the necessary safety gear.
As for sharpening your tools here's a link for a good start. Good Luck with your lathe.
Again, nice job on the saw.
Scott
Sharpening primer
Re: Built a Bowsaw
Re: Built a Bowsaw
Stuart,
The lathe was a great find on Craigslist, it was rusted from sitting and was listed as "not-working,I think the switch is broke,so I can't tell you if the motor runs"...what that turned out to be was the safety insert was missing from the switch,good thing my jointer uses the same one,so I got the lathe VERY cheap.
And I thought everybody had a waterjet???How else does one cut stainless steel infill plane parts?: )
Thanks for the comments,
Andy
