200+ woodworking book reviews
OT: shipping tube radio
Somehow, I acquired a 1936 Motorola car radio, which I may offer up on deBay. It was produced a few years (like 15-20) before the commercial application of transistors, so it's got four or five tubes, still firm in their sockets.
I can figure out how to box it up, but wonder if I should wrap anything around the tubes to keep them from sideways movement during transport. Logic tells me the sockets must have been engineered to handle movement; I suspect the average 1936 auto on the average 1936 road encountered more violent movement than this radio will, swaddled in a foam-lined box in the back of a USPS truck. Still, I'd hate to have it arrive damaged - assuming there's someone out there who's been pining away for one of these, that is.
Re: OT: shipping tube radio
scott grandstaff
scott grandstaff
Just pretend you are going to stand on top of a football stadium and give it a boot down the 126 cement steps.
The chassis will be fine. Its the whole radio you have to worry about.
Peanuts will shift in transit, bubble wrap is better. Three times around and box it.
Double boxed, bubble wrap in-between the boxes, you can ship it to Ecuador.
I have shipped antique glass around the globe this way.
yours Scott
steve mackay
I ship my mounted models with the same consideration. Best bet is to "block" protruding parts with syrofoam then scroung a big block that was used to ship an apliance or such and "mount" the whole rig in a "cutout". Then wrap and box. Even with several wraps of bubble wrap the standing parts can still take stress when the whole rig shifts against the side of a box without some sort of rigid support. The ideal would be to mount your rig to a base then mount inside a wooden crate but that would cost a fortune to ship. Many unhappy clients over the years have taught me that the more rigid the better.
Thanks, Scott and Steve
The box is a true brick, with nothing sticking out except one flattish knob, and a wire out one corner.
My plan has been to build up a styrofoam box - I've got some 2" sheet foam insulation - tight to the radio. Maybe even cut it properly on the tablesaw (bits of styrofoam flying everywhere...) and construction-adhesive it together, although just taping it up might be enough. Then build a cardboard box tight around the styrofoam. I have debated whether to put an extra layer of soft foam around the radio, inside the styrofoam. If I'm understanding your joint advice properly, allowing that kind of movement might be worse for the radio than the firm support of the styrofoam.
Finally - Something I Know About
R.J.Whelan
Bill,
Remove the tubes and label them with masking tape (with corresponding number on the socket).
Wrap each tube separately - upholstery foam is good.
Be cautious when removing the tubes as the heat from these old radios has an adverse affect on the material the socket is molded from. If the socket appears cracked (when you get the tube part way out) - shove the tube back in place and tape it down (be sure to advise the seller about the tape). If the first socket is cracked, don't remove any of the tubes; tape them as previously described.
The chances of 70+ year old tubes actually working are pretty small, but some of these old tubes (in working order) are worth a lot of money. There's actually a little cottage industry that renovates antique tubes: cutting them apart and installing new plates and grids and then evacuating the air.
I worked for Kenwood (the audio company) for 25 years before retiring in '02. I was actually in finance, but you can't work for an audio company without picking up a little technical knowledge.
Best of luck with the shipping .... rj
What you're describing . . .
steve mackay
sounds on-the-money ! My measure is if I think they could pitch it out da' airplane over the adress and all would be well. Wich, I think, is how some stuff gets to my door !
