A refurbed Bedrock Type 5 606C
Dominic in Buck's County PA
Hi gang,
A week or so ago I picked up the sole and frog for a Bedrock Tye 5 606C off of Ebay. I got it for a pretty good price (at least I THINK I did). But as you know, I'm a sucker for Bedrocks. Especially ones that need a bit of TLC.
This baby arrived and after looking at it I was convinced that I could make a go out of it. The body was rusted to the point where the japaning was gone. But the sole and sides were really not that. The frog was in somewhat decent shape and the hardware needed a severe cleaning.
I ended up soaking the frog and body in Evaporust not once, but TWICE. Let me tell you something, when Evaporust goes BLACK, that means it DEAD After dunking it got cleaned with a brass wire wheel.
Cleaning the sole amounted to stripping off the rest of the Japaning and then prepping it for spray painting. I masked all the mating surfaces with blue painter's tape and went to work. I used Rustoleum primer (the kind that converts rust to a paint able surface) and then over the next couple nights I gave it 6 coats of Hammertone black satin enamel.
After the paint was dry I addressed the sides, sole and the rest of the plane. The sole was corrugated. So that made flattening a breeze. The sole and sides are not pristine by any stretch of the imagination. The sides have areas of small pitting as does the sole. I had some concern early on that the area in front of the mouth would be damaged. But it turned out to be more like a discoloration rather than pitting. And none of these intersect the leading edge. So it is not a worry (as you can see from the shavings in the photos below). After lapping, I gave all areas a nice buffing up to 600 grit.
I had a very nice old rosewood tote and knob that I just refinished waiting for this bad boy. They were given several coast of blond shellac rubbed out with 0000 steel wool. I must say that now I know why craftsmen preferred rosewood. That stuff finishes beautifully!
I had a Bedrock Lever cap that had a chipped edge. I carefully ground that down smooth, sanded it and polished it until it looked perfect. Next to an identical one you can hardly tell the difference. And what's more, it works just fine.
The tote and know hardware as well as the iron and chip breaker came from that crappy old 4 1/2 I parted out. I have no idea what that plane iron was made from but it took me nearly 1/2 hour to use diamond paste and a steel flattening plat to lap the back flat! After that I sharpened with Japanese Super Stones and honed with LV Green Honing compound. I'm not saying that I got the edge super sharp or nothing. But I was afraid to put it too close to anything because it might come in contact and cause a fission reaction (you know,...because it was SO sharp that it would split an atom,......eh,.....ah,...........................................No one gets me)
Well, here it is. It isn't going to win any beauty prizes, but I like the way it performs. And that's all that counts.
And here it is working on some walnut, alongside it's smooth soled "brother".
As you can see, it can pull a nice shaving. And it leaves a surface as nice as my other 606. I plan on cambering the blade a bit more and using this as a "surfacing" plane.
Thanks for viewing
See ya around,
Dominic
