Veritas Round Spokeshave Question
Dave (Arlington, VA)
Hi All -
I have just started using a new Veritas Round Spokeshave to help shape parts of a canoe paddle I am making. I really like the look and feel of the tool. I have sharpened the blade but I am still getting chatter and tearout when I use it. Anyone have any tips on the use of these tools? I've used my old Stanley "flat" spokeshave quite a bit and it works just fine -- even with a thinner blade. Having problems with this new tool and I suspect it is user error.
Thanks -
Dave
Re: Veritas Round Spokeshave Question
The bearing surface on a round spokeshave is really really tiny. Unless the curve you are planing is exactly the curve of the spokeshave, a rare event, the shave bears on the edge of the sole in front of the cutting iron and the edge of the cutting iron. So chatter is ever lurking.
Of course, the edge should be as sharp as your skills can get it, and the cut fine.
I find, in my limited experience, that round shaves seem to work best for me if I draw them toward me rather than pushing - while, with flat shaves, I more often push.
Also, the grip I learned from a Fine Woodworking article some years back, with the thumb and first finger gripping the "body" of the shave just inboard of the handles, with the handles serving only as somewhere to put the rest of the fingers so they don't get in the way, seems to help, because it gives you finer control of the shave's angle of approach to the wood.
Just a thought
Wiley Horne--So. Calif.
Dave,
I have only used a convex shave on one part of one project, and found it a difficult tool to just 'sharpen and use'. So I'll offer my experience, with the caveat that it ain't much experience.
I eventually was able to use the tool productively, but only after some unhappy moments like you are describing. This may be obvious to you--it wasn't to me--but it's hard to find the sweet spot of a convex shave. With a flat-bottomed shave, there is only one choice--the shave has to be flat on its face. With the convex shave, it will only cut properly at one angle, but you have to find it. And it will also only cut properly if you have the right blade projection.
Initially, I kept setting too much blade projection--this was on a shave without an adjuster. What would happen is that I would fail to make a test cut when the blade projection was right, then advance it more to get contact, and then that would be too much and I would get chatter.
So I would suggest this diagnostic: using your adjuster screws, set the blade at a slight skew, so that it transitions from 'no cut' to 'some cut' across the shave. Then take a thin stick, like 1/4" wide, and find out where the sweet spot is across the shave. Once you find the sweet spot, then use the adjuster screws to level the whole blade and broaden the sweet spot. You could make the sweet spot go all across the shave face, or else could leave a little skew in the blade as some like to do. Shave on the thin stick until you have a curve in it, comparable to the curve in the project wood. Make adjustments to blade depth as required, as the curve deepens.
The point is, to focus down and find the sweet spot on a thin stick. Now you know you have the blade depth right, and you have some muscle memory finding the correct angle to hold the shave at. BTW, I am assuming you're holding the shave close to the cutting action, and not spreading your hands to go on the handles. You want your thumbs on the cutting head (IMO, IME).
So now you can turn to the project wood. You should be within fine tuning of good results.
That's what I did. Worked OK, but with the grain only.
Wiley
I Agree with Bill on the Proper Grip
Larry Wyatt
Thank you, Bill
Bill -
I appreciate the advice. I think I was holding the spokeshave as you suggest, but I'll be more premeditated about it and make sure to give it a shot.
Also I just realized that I was sharpening the wrong thing ;-(
Lee Valley has a pretty good sized (in my non-professional judgement) micro-bevel and I haven't been touching it. The back is shiny and the bevel is shiny but the microbevel is not. So I'll have to take care of that too.
Again, thanks!
Dave
Thank you, Wiley
Wiley -
I do the skewing thing with my flat-bottomed shave. So that makes sense here, too. I think it particularly challenging because the bottom of the shave is round, and the think I am trying to shape is curved, too, so finding that sweetspot will be the trick.
I appreciate the advice!
Dave
Dave Mount
Dave--
I have that shave (and its two sisters), and I think Wiley's got it right. If the shave is not contacting the wood in an orientation that has the iron at its lowest point, then when the shave starts to cut in it digs and causes chatter.
I have a related but slightly different suggestion for finding the "sweet spot" and setting the projection. Use the flat edge of a board, set an initial guess at projection, then take a pass over the edge of the board, rotating your wrists in an exaggerated way as you pull the shave toward you. The idea here is to rotate through the different potential cutting angles as you make a stroke. If you don't get any cut and any point in the stroke, lower the iron a little. If you get a heavy shaving and/or chatter, reduce the projection. The goal here is to get the iron set to where you only take a modest thickness shaving and only at a particular angle. You'll quickly figure out where that is.
When working your paddle, do the same thing to find the sweet spot. Sort of over-rotate your wrists on the initial passes to locate that sweet spot, then work from there.
As I said, I have the same shaves, and I love all three (flat, convex, concave). I used them on a set of five paddles myself. The convex shave was great for working the blade/shaft transition and the shaft/grip transition. If you're having trouble, I'm almost sure it's a problem with the setup/angle of attack. I've never used such chatter-free shaves (caveat; these are the only high end shaves I've used, the rest were vintage Stanley etc.).
Pics of the paddle project?
Best,
Dave
Hi Dave -
Thanks for the advice and encouragement. I have been fiddling with my flat bottomed shave as you, Bill and Larry have suggested and I have had more luck. I have decided to re-grind the blade on my convex shave and that is taking some time since I'm also trying to continue to making what progress I can on the paddle.
It is encouraging to hear of your success in using these shaves. I will keep at it...and try both your and Bill's strategies on finding the sweet spot.
Thank you!
Dave
