Suicidal Tendencies??
scott grandstaff
scott grandstaff
Well, remember the ax handle pattern I carved on the new shave horse??
I went ahead and mounted it to an old ax.
Ordinarily you would have to be insane to pick Pacific Madrone as an ax handle.
But this particular tree was a freak. It was twisted and interlocked as bad as elm from one end to the other.
A 10 pound maul and 2 steel wedges couldn't phase it.
I had to borrow a hydraulic splitter!
So I figured I'd give it a try.
If you look real close there is still a little bit of bark I left just at the bottom, so's you'd know where it came from.
If it snaps off and kills me, the paper will pick it up,...... eventually :)
heeheheh
I did at least give it a real good workout before I went to the trouble to finish it off. It seemed to hold just fine.
Time will tell.
yours Scott
Re: Suicidal Tendencies??
Unless you're a madman with a hatchet, that seems like less of an issue than if you'd used an uncertain wood on a splitting maul or felling ax, where the head spends significant amounts of time over YOUR head.
Purty handle.
scott grandstaff
Re: Suicidal Tendencies!?! *LINK*
scott grandstaff
Do you play rhythm or lead?
Hey I'm easy. I'll play rhythm or lead or ease it down sweet and give anybody else a chance!
I'll even share my mic................................
sporadically
heeheheheehehe
yours Scott
music
thomd
About 30 years ago I put a softish piece of cherry on a Jap. chisel hammer. I figured it would break, but it was all I could find at the time. Still going strong. I think one can get away with a lot given: 1) Few people use this stuff 24/7 as in the old days; 2) As wood folk we presumably get the grain right, and the head on tight; 3) Some of the woods we might choose don't see general use only because they are too pricey. 4) One can radically improve the performance of a particular section by how it is shaped.
Interesting bow rule holds that all woods are equally efficient as long as the limb width is widened in lighter woods, and to the degree the overall weight is the same.
Hmmmmm...
Scott Burr in Ben Lomond CA
The only Suicidal Tendency I see would be cranking that bass to 11 in front of that wall full of glass :D
Nice job on the guitars as well!
