drop leaf table
Patrick Gibbons
I'm making a small drop leaf table with a round top of approximately 29" diameter. Would a butt hinge work to attach the leaves and the braces? Anybody made one and have some words of wisdom to pass by me?
drop leaf table
Patrick Gibbons
Rule or butt joint?
If you're using a rule joint - convex edge on the main top, concave on the leaf, so that, when the leaf is down, you have a smooth-looking detail and so that the wood provides some support for the leaf, not just the hinge - anyway, if you're using that, there are special rule joint hinges, with one longer leaf to jump over the concavity in the leaf.
My grandfather did several utility drop-leaf tables, with butt joints, and just set the hinges in place with the barrel down.
Re: Rule or butt joint?
Patrick Gibbons
Butt joint it is Bill. Thanks for confirming what I thought. Never done one of these before.
Follow up thoughts
Mortising the hinges into the tabletop and leaf edges - as if the leaf is a door and the top is the jamb - should be stronger, as the hinge screws will be in shear, while if you just slap them on underneath, the stress will all be in trying to pull the screws out.
