No46 Clean up
No46 Clean up
No46 Clean up
Dominic in Buck's County PA
Hi everyone,
While I was waiting for the primer to dry on the 606C I'm working on, I decided to tackle this sweet little No46 I got several years ago but never got around to cleaning up.
No46 BEFORE
No46 BEFORE
No46 BEFORE
IMHO these combo planes really perform a lot better once they are cleaned up and the fences can slide easy on the guide rods. Otherwise, they are too much of a PITA and you never end up using them.
It was a simple clean up. I just took everything apart and then wire brushed each piece individually. Then they all got a coat of oil, were wiped off and re-assembled. The irons are from St. James Bay co and were purchased recently. Can't remember what I paid for them, but I do know they were cheaper than trying to find antique ones, and they were in MUCH better shape.
No46 AFTER
No46 AFTER
No46 AFTER
after the No46 was re-assembled, I took it for a short test run and set it up as if I was cutting the groove for a drawer or box bottom (a task I will be doing soon). After some minor tweaking, it worked like a charm.
No46 AFTER
Thanks for viewing
See ya around
Dominic
Re: No46 Clean up
Re: No46 Clean up
Wiley Horne--So. Calif.
Hi Dom and all,
Dom, that's a wonderful job, because it's so clean, but doesn't look over-bright (too shiny).
Question about the 46: I see it is skew-bladed. But I can't see a nicker on it. Is there a nicker, or is it like a skew plough?
Thanks,
Wiley
Re: No46 Clean up
Dominic in Bucks County PA
Re: No46 Clean up
Hi Wiley,
thanks!
yeah, there's a nicker. It's on the body. There is also one on the fence.
Re: No46 Clean up
Hey, That looks familiar!
Scott Burr in Ben Lomond CA
'Bout time you got around to this one :D
Nice cleaning job Dom.
What did you do to the wood parts (if anything)?
Re: No46 Clean up
Re: Hey, That looks familiar!
Hi Scott,
Yeah, it HAS been a while since I got this hasn't it? But This isn't the one I got from you. :D I stole some parts and sold the remains to a friend.
And as far as cleaning the wood, a diluted solution of Murphy's Wood Oil soap is all I used.
