200+ woodworking book reviews
Dimensioning discovery
Paul M.
Hi Folks,
I was dimensioning wood for the rails and stiles on a set of four doors recently and discovered a way to do the dimensioning by hand plane rather quickly. This is probably old news for many of you, but was an a-ha moment for me.
The toughest part of dimensioning stock by hand has always been getting the faces flat and parallel. I can joint one face to be flat (using my workbench as the reference surface), but then marking and planing to the marks to get the opposing face flat has always been a bit tedious and time consuming. Lots of lifting the piece to check the marks and strain on my bad eyes. I found a great shortcut... Just use my fingers!
I dimensioned one stile (longest one) to be flat on one face and carefully planed to desired thickness + 1/64 on the other face using a marking wheel to guage the thickness. I clearly marked this stile as the reference piece and layed it on my workbench.
I then jointed the remaining 15 rails and stiles for these 4 doors to get a flat face, and then just planed the unjointed side down until I could feel that 1/64" with my fingers along the entire length of both edges. Just lay these two boards side by side on the bench and run your fingers along this to feel that small gap where the board you are working is consistently lower than the reference board. Rotate the board you are thicknessing around it's length to check both edges. If they are consitently below the reference thickness, then you're done.
This saved a lot of measuring and fiddling and made a tedious process quite fool proof.
