Workbench: I'm declaring victory
wilbur
My workbench is pretty much done. There are still a few things to do. I still need to make a sliding deadman, but I've found that I have other ways to deal with edge planing longer boards for now. I also need to tune up the handle for the vise, put some boards across the bottom stretchers for extra storage, and make a real pin for the leg vise instead of the 3/8" oak dowel that I'm using. I also want to hang an additional fluorescent light fixture above the bench.
But the bench is in position, and I've got the key parts of my wall tool storage up and running. As you can see, I decided to go with unfinished pine boards. I might decide to paint the pine boards later on, but that will be easy for me to do if I go that route, since all the tool storage is just screwed onto the pine boards.
So I'm finally declaring victory on this project. And it only took 18 months. ;)
The exposed 2x4's to the left of the bench is where my sharpening table is. It's not there now so I can mount pine boards onto the 2x4's like I did for my workbench.
Re: Workbench: I'm declaring victory
Moses Yoder
Moses Yoder
I find it kind of interesting that you have all those Eastern style tools and a western bench. Did you think about just using a beam as a workbench?
Stephen Shepherd
Stephen Shepherd
Victory indeed, congradulations Wilbur, nice work and great documentation of the process. It was great to get a preview last night on the Hand Tool Chat.
Stephen
wilbur
Hi Moses,
I did think about making a planing beam. The problem with a planing beam is that it provides a solution to exactly one hand tool task: planing. I still would need a place to pound chisels, and to saw.
I think that what is missed in the few pictures there are of Japanese woodworking shops, like Toshio Odate's, is that they seem to be consistently build on a low platform of one sort or other. This is where all the assembly and work really takes place. I think that the platform is really the Japanese "workbench", and that the planing beam, low horses, and small planing beams that are braced against your body are all really bench appliances, like a shooting board or a bench hook.
I didn't have a practical way of building or locating such a platform in my shop, and I thought that I would need a vise of some sort. So I decided to go with a Roubo style bench. The main reason that I picked this bench is that the front right corner of the bench is wide open. Without an end vise, I can put a planing stop for Japanese planes in this area, in effect turning the front of the bench into a planing beam.
You can't see it in the picture, but I installed two threaded inserts where the board is between the clamps and the hammer towards the right end of the bench top, and put flat head brass machine screws in the threaded inserts. A piece of wood across the screw heads makes a great planing stop for Japanese planes, and I made a countersink so that I can drop the screw heads below the bench top surface if I need that area of the bench for some other task.
Clever planing stop idea
Lovely, lovely bench
I - like many of us, I suspect - have enjoyed watching you design, build, and solve problems with this bench. The final product is truly nice.
You are a wildman Wilbur!
Bob Hackett
Getting to see you thrash thru this and make progress in fits and starts and your story presented warts and all has been a real inspiration.
Here`s a real world guy staying true to his dream no matter what,and with hand tools no less.Neanderthal reality TV at it`s best.
Thanks for sharing this here and thru your blog.You give the rest of us poor schlubs hope,truely.
I had thought of having "What would Wlbur do?" embroidered on my shop apron.
Do you think it too over the top?
No logo(like crossed chisels or a plane with curls emerging) just the simple question,in tastefully colored thread. ;)
MB
Paul Kramer
Really Gorgeous
Paul Kramer
Wonderful, Wilbur
Hank Knight
Your bench looks great! I know you will enjoy it. It took me well over a year to finish my bench, and I was more than ready to use it. I know you're there too. Great job and thanks for taking us along on the journey.
Hank
ThomD
That's a very clean looking bench, congratulations!
Look real nice Wilbur...
Scott Burr in Ben Lomond CA
Thanks for taking us along for the ride as you made it!
Now, what's up with all those electrical outlets? :b
You should declare victory
Bruce, a MN Galoot
that's a darn nice bench: functional, behemoth, perfect for what you do. It's just my orientation to the way things should work - I like tools and stuff that ihas minimal ornamentation and does its job with very little fanfare. That bench is all that and your wall o'tools fits so well.
Very well done.
Jack Guzman from Maine
Looks great Wilbur.Awesome job and thanks for sharing with us. Next I'd like to see some projects that come off that bench. ---Jack
Looks great Wilbur! Nice job!
Stuart Hough
Re: You are a wildman Wilbur!
wilbur
Hi Bob,
Asking "What Would Wilbur Do?" would be a good way to figure out how to do things in the shop. Once you figure out WWWD, then do the opposite, and you'll be good. ;)
Re: Look real nice Wilbur...
wilbur
Hi Scott,
Good pickup on the outlets. ;)
When I was initially laying out my shop, this was the wall that I thought my lathe would be on, and I decided to install more outlets than I could conceive of using, so that I wouldn't have to go back and add more later on. The workbench I was using at the time was at the other end of the shop, where there are few outlets.
Now the lathe is over in that end of the shop, and my new workbench is where the lathe used to be. So it goes to show how much things can change as a shop evolves.
In keeping with Bob's WWWD? philosophy, this would be a perfect example of figuring out what I would do, and going with the opposite plan. ;)
wilbur
Hi Jack,
My first projects are already under way. I've been making more purpose-made tool hangers and mounting them on the pine board wall. This has been going really quickly.
I was surprised as to how fast I was going, and then it hit me that the difference is that now I have a real workbench to work on. Also, I'm not banging out 1" wide 2" deep mortises any more. ;)
Marv
Wilbur,
Might fine work.
18 months? The longer it takes, the greater the investment of time and the more you can appreciate it. It's probably the getting there that is more satisfying than being there.
Have you put a sealer of some kind on the wood?
Glad you didn't clean everything up for the photoshoot.
Marv
wilbur
Hi Marv,
I'm leaving it unfinished. As thick as the top is, I can always flatten it out and put a finish on it if I think I really need it.
The sad thing about my picture is that I did clean things up for the photo. ;)
Wiley Horne--So. Calif.
Congratulations Wilbur!
Am sure you're glad you took the long road. Bench is just magnificent.
You made the right choice, leaving the pine natural. Everything looks like it belongs this way.
On the electrical outlets, you may eventually be glad that they're all there. I'm thinking particularly of task lighting, where you want to get some directed light on the joint you're sawing. Also, the hot hide glue needs to plug in somewhere. And the Tormek. At some point, you may want a Dremel or handpiece of some kind to do some fine grinding....
Will you use the leg vise for sawing joinery? How will that work?
Wiley
Re: Workbench: Looks Great!  Can't wait to see it!
John Aniano in central NJ
wilbur
Hi Wiley,
First of all, I have to thank you for talking me into pounding out those 1" mortises by hand. It may not have been the most efficient way to make those joints, but now I have a really cool story to tell, and chopping furniture scale mortises by hand is a piece of cake for me now.
I've been doing most of my sawing off of the right side of the bench. I'll probably use the leg vise for sawing some joinery, like dovetails or cheek cuts for a tenon fi the workpiece is too long for me to conveniently lay it down on the bench. We'll see what happens in the long run.
Bob Entwisle in NJ
I'm late to the party as usual.
But:
NICE JOB WILBUR! (and yes I did mean to shout!)
I'm afraid that WWWD, and then do the opposite, is just not going to cut it anymore.
I know that for you the best thing about your bench its that you have a bench and it is finally done.
For me, and I think a few others, the best thing about your bench has been your detailed documentation, thoughts, and personal woodworking revelations along the way.
Thank you for an inspirational journey.
I hope it provides you with many years of woodworking enjoyment!
Bob in NJ
Bruce, a MN Galoot
My grad school adviser had a sign above his desk that read "Show me a clean desk, and I'll show you a scared man."
