Another Shave
Another Shave
scott grandstaff
Another Shave
scott grandstaff
Hey
Remember last month I restored 2 great boxwood spokeshaves??
I had got the Marples mini and realized I had a Spear and Jackson hanging off the peg waiting to be restored.
The Marples is a high grade of boxwood, and the S&J is just phenomenal!
Both are nearly grainless and hard as rock, but the S&J is approaching granite it is so hard and buttery too!!
Well, I had an opportunity to get a big boxwood shave. The 12" size. And it was dirt cheap!
It looked like the others had in the pictures. Namely mungy filthy and paint drips, but all there. So I jumped on it.
Well, when it arrived I took one look at it and tossed it on the shelf in disgust.
It had the wrong blade in it, that didn't come close to fitting.
It had deep scratches and some cracks and seeped in stains.
The stains bothered me. It would be hard to get heavy boxwood, the good stuff, to stain at all. It is so dense I couldn't see much stain soaking in. Maybe if you boiled it in tea like the Chinese do?? I don't think Chinese boxwood is as hard as old English either.
Well, I got the thing back out yesterday.
The worst part of the any-old-blade was that the tangs were way too small. The width between tangs was close enough, but the holes for the tangs in the shave body were gargantuan by comparison, and would never hold.
I had to think about this a bit, but came up with the obvious solution. Shim out the holes!!
This will work on any shave with sloppy tang holes just as well, btw.
I took a dinky square file and evened up the tang holes, removing decades of grime in the process, to fit the "new" blade and also give me a good glue surface.
Seeing as how I was already going to cut and fit tiny slips of wood?? I decided one of the most classic boxwood trim details is ebony so I cut some. They were around 3/16" wide by ~1/32" thick! I had to get 4 of them to glue to the walls of the square holes somehow,
so I took some plastic material.
Low-blow polycheapalene from an old cutting board to be exact, and cut two squares into the proper size, a bit smaller than my tangs but considerably longer, tapering them good near the ends.
Just to be able to start them.
No glue made by man sticks to polycheapalene, and it has some strength yet is also has some flex and compressability.
A glue caul the perfect imitation of a shave tang!
I glued up my ebony shims and placed each one against its sidewall then started the poly square and drove it home! Naturally the ebony shims were 3 times longer then they had to be, so I had a prayer of getting them all in. :)
When the glue dried (regular carpenter's glue, btw) The poly squares drove right back out slick as a whistle, with my trusty 8oz.
Cleanup was easy. Sawed off and filed them flush.
Then it was time to actually fit the tangs to the holes. This involved the same square needle file and some cut-n-try time.
The tangs are tapered and the holes need to taper and you want a driving fit that holds tight but isn't so tight you break the shave getting them in.
Now that the blade was seated in the shave body, there was another problem. The blade was very much shorter, front to back, than the blade the shave had been made for.
So I had a throat you could toss a thrashing alligator though!!
Wooden shaves don't need a super tight mouth like an infill plane or anything. But you shouldn't be able to drop a 2X4 past the blade either!
Since I was using ebony for the.... "tang liners" (heehehehe, new term) I decided to just use ebony for a wear block as well, instead of traditional brass. I had the brass out. I thought about it..........But against the boxwood??
Ebony makes smokin' hot contrast with the yellow boxwood!!
I didn't like that it wasn't ridiculous hard to cut the pocket for the ebony, but I went on ahead.
When the glue was dry it was finally time to scrape the shave clean and give it a polish and enjoy the boxwood!!
Boxwood is so cool.
It scraped too easy!
Oh crap.
It was the color of boxwood alright, and probably is some kind of boxwood relative, but some Englishman of the prior century was pulling a fast one!
Hey....this ain't the stuff!!
Sure its yellow, and sure its hard but it ain't in the same league as the Marples boxwood and not even on the same planet with the Spear and Jackson stuff. It scraped too easy and sanded easy too. About like hard maple or maybe beech. Nothing like the rock hard boxwood we all know and love!!
I know the English countrydide was stripped of it pretty early. Spain next. On to Turkey. Then down to Morocco.
Wonder where this stuff came from? It has some dark streaks in it too. It makes me wonder about the more moden boxwood handles and such?
With the previous shaves, the wood was so hard that after it was scraped and sanded, I was able to polish it like it was metal, and look brilliant about it! No further finish necessary or desired.
This shave, well when it was ready I tried to polish it.
All it did was soak up polishing compound. Not the look I was going for!
I had to scrape it all again and sand again and resort to lacquer, after a quick wipe with linseed. But it at least looks....
boxwood-ish.
It works a treat too.
There's nothing like a good wooden spokeshave!
Oh I love iron shaves too, don't get me wrong,
but the wooden shaves are just effortless joy to use!
Oh PS, scrapin and shapin a spokeshave body on a good shavehorse, is a delight beyond words ;) ;)
yours Scott
Re: Another Shave
Excellent reporting, Scott. Thanks.
How are your ebony shims working out as tang liners? Do you get enough "tooth" to hold the blade firmly?
Re: Another Shave
scott grandstaff
Re: Excellent reporting, Scott. Thanks.
scott grandstaff
Thanks Ellis
Yeah so far its hanging on like a pit bull on a pork chop!
heehhe
But then I didn't fit em' sloppy. Takes a reasonable stiff swat to seat the tangs.
The tangs are not supposed to be smooth polished. Nicely forged, but not ground and polished. Makes for sticky tangs.
I like to slightly hollow grind the back (bottom) of a wooden spokeshave blade.
Not a lot, basically relieve the backside of the blade some for clearange and then hollow a mere fraction just behind the edge.
This makes it total cake to flatten and maintain your clearance too!
Got to steal somethin' from the Japanese ever once in a while..... heeheeh
I was just hogging some black oak out of the scrap box, for fun.
Wish you could have a try.
yours Scott
Re: Another Shave
Just generalizing
I have found that wedges in general need to be a tad softer than the things they're wedging, otherwise the vibration and coefficient of restitution (or whatever is at play here) can loosen the interface, depending on how the surfaces interact. Probably generalizing too much, but maybe this can spark a more general discussion of densities and side hardnesses and such as aspects of tool engineering.
Re: Another Shave
Those are SWEET!
Scott Burr in Ben Lomond CA
Thanks for the right up Scott. I've been leery of old shaves like those for all the reasons you just showed how to fix. Guess I'll have to keep my eyes out for 1 now...
Yea, like I NEED more spokeshaves ;)
