Crown Gents dovetail saw handle conversion
Dominic in Buck's County PA
OK, so I have this Crown Gents Dovetail saw and I've been wanting to make a new handle for it for the longest time.
The handle just popped off with minimal force. Here is a photo with the template of the Graymercy Dovetail saw handle
I then cut the "tang" off of the saw plate and then used a dremel and abrasive cut off disk to cut an angle at the back of the saw plate. This angle matches the one on the Graymercy template. Notice the spine is angled as well? That'll be cut straight later on.
I chose some very cool looking lacewood for the handle. It's a bit light but the weight compliments this small dovetail saw nicely. After surfacing the blank to just a bit over 7/8" I attached the template with some 3M spray adhesive, and drilled out the curves, then bandsawed the shape out.
I then drilled the holes in the handle for the saw nuts using the locations on the template. These holes will help me to locate the holes in the saw plate.
I then cut the kerf using the same technique as I used during my Disston Keystone Dovetail saw project. Once the kerf was cut the mortise for the spine was let into the handle.
After that I used a transfer punch to locate the holes in the saw plate
Then the handle was shaped, scraped, sanded, and given several coats of blonde shellac.
And here's the completed saw:
It feels very balanced in my hand. And I like the shortness of the plate. It'll be perfect for smaller projects. I need to wait until I get my Somax saw set from TFWW. Then I'll sharpen it up. Right now it doesn't cut well at all
And here it is in it's new home (until I make a hanger for them on my inner cabinet door)
Thanks for viewing.
See ya around,
Dominic
