The Saga of the Pruner Handle "Project"
John Aniano in Central NJ
Hello All,
About 10 years ago my wife Debbie and I bought a Japanese-toothed pruning saw for working in the garden. It got a lot of use, and finally the blade became dull. With it's impulse-hardened teeth, I could not file it, so I recently bought three replacement blades on eBay. One blade fit the old handle perfectly and we were back in pruning business.
Then I thought "I have 2 more sharp blades, why don't I make a new handle for one of them and we will have a pair of pruning saws". That was my first mistake.
Copying the original beech handle looked to be an easy project. It consisted of two holes for a pair of saw nuts I had been saving for just such a project, a simple curved profile, a bit of rounding, and I had a large 10 foot long plank of 1" thick quartersawn beech I had bought for making saw handles. I then said to myself "That beech plank is huge - it will take a lot of effort to get it into my shop and hand saw a section off to make this little pruning saw handle". Then I noticed the small, narrow strips of bloodwood my friend Stephen Thomas had given to me a few years ago. "Perfect size!" I said, and carried one of the bloodwood pieces into the shop and traced out the handle profile. By this time, I had unknowingly made several more mistakes in judgment...
I drilled out the holes for the saw nuts using forstner and brad-point drills on my drill press. Easy task! Part of the profile matched a ~1-1/4" forstner bit, so I drilled fully through to make this portion of the profile. Not so easy! - the forstner bit protested! Then, with my bandsaw, I began to cut out the rest of the profile. That is when the burning smell began. I should have stopped at this point, but forged ahead while the acrid bloodwood burnt dust settled onto my shop's horizontal surfaces and formed a fog in the shop. I should have called it quits as I used the bandsaw to cut the slot for the blade, but kept on going. I had to open the shop windows to let in some clean air...
This project was to become my "INTHMHE" saw handle.
"I Need To Have My Head Examined" I said as I began to try to smooth off the profile with my antique wooden spokeshaves. One spokeshave after another failed to cut the dense bloodwood. The stuff was turning the edges of the antique cast steel blades! Finally I found one spokeshave that protested, but cut, albeit slowly. (The blade angle was ~30 degrees.) "What was I thinking" I said to myself. "This 'simple' wooden handle will take hours to make at this rate!" "Why couldn't I have used the beech?" INTHMHE!
With the protesting spokeshave, I cut broad bevels on either side of the profile and when the bevels were done, I used the shave to round off the edges. In the concave regions of the handle, half-round files and a bow making knife made of HSS came to the rescue. The files clogged as though I was filing aluminum! My German hand-cut rasps fared a bit better, but were only good on the convex regions. INTHMHE!
Some really tough 3M sandpaper worked great to smooth off the rounded portions of the profile. The flat sides of the handle were smoothed with a minimum of tearout with a smooth plane.
Time was spent getting the saw screws and nuts to fit into the aluminum-like bloodwood. A narrow chisel and gouge got this task done. I test fitted the screws and made sure the blade could be held secure with the nuts.
Being the perfectionist that I am, the whole shaping and blade-fitting processes took maybe 2+ hours over three evening sojourns to my shop. INTHMHE...
Finally, I immersed the handle in a jar of linseed oil and turpentine I have for just such occasions. It remained there for 5 days. Often there is a foam of bubbles on the top of the oil when I immerse handles made of normal woods, but with this alumnio-bloodwood handle, no bubbles were observed...
After fitting the blade for the last time and a coat of a wax/linseed oil mixture this "simple project" was done.
Dense. Hard. Bloodwood. My brain. "Why couldn't I have used the beech?"
INTHMHE...
Re: The Saga of the Pruner Handle "Project"
I have a great deal of sympathy
because I have, more than once, bulled through on something and made myself oodles more work because I didn't stop and ask, "Is this the best approach?"
Nice looking saw, now that you're done. You can be proud of it.
Saga yes, Seems worth it to me...
Scott Burr in Ben Lomond CA
Kinda... Wouldn't it have been easier to take the handsaw out to the Beech and prop it up?
Never the less that's a great handle. You did a job on it!
Just so you know, chain saw are more fun :D
Re: The Saga of the Pruner Handle "Project" *LINK*
Wiley Horne--So. Calif.
Really beautiful job, John! Looking at the final result, one would never guess at the misery involved in getting there. Which speaks of someone who is prepared to go the last mile--and then another last mile--on a tough job to make it exactly right.
Looking at the bows on your site, www.jbabows.com, I now see that every single one of them represents an intense commitment to the last details of a very exacting task.
Thanks for sharing,
Wiley
John's amazing bows at www.jbabows.com
I don't want to show you the pruning saw...
...handle that I made on a whim one day. The blade was one I took off of a new telescoping-pole lopper. I made the handle from ipe and bolted it together with hex head machine bolts and nuts set into counterbores. (Where is the best place to get saw bolts, by the way?) Crude but quick and functional.
Anyhow, I appreciate the hand-held pruning saw, and it works for so many pruning jobs. My wife loves hers.
Nice job. Thanks for posting.
The best place to get saw bolts
used to be Todd Hughes' pile of saws, if you could sneak in when he wasn't looking.
I've picked up a few dead saws in my time and have some saved in the hardware stash (in fact, if you need any, let me know). My local Ace hardware has some - they're not very attractive, all aluminum construction, but they would probably not require the careful counterboring of the good brass nuts.
I'm always needing a pruning saw or clipper *LINK*
on the end of a 4- or 5-foot stick. In other words, some reach to keep me from needing a ladder. But not a full on pole saw.
Saw bolts. Mike Wenzloff advertises he will sell any saw-making part, saw blade toothed or not, nuts/bolts, backs folded or slotted, a full saw kit, or a hand-made saw--whatever you want. See the link below--look for "Saw Parts--A la Carte". Mike Wenzloff is a great guy.
Wiley
Mike Wenzloff--A La Carte Saw Parts
Re: I'm always needing a pruning saw or clipper
David Weaver
He will, and his prices are reasonable, more reasonable than I think a lot of people would work for.
If you ever need 1/8" naval brass for the sides of planes, he probably has a better price than you can get it for anywhere else, too.
Heck of a nice guy.
Checked them out
It looks like they have a nice line of saw bolts, but with the tax and freight, two SS fasteners would run me about 12 bucks apiece. Makes me feel a lot better about my homely hex bolts. I do like the idea of salvaging a couple from a junker saw. I know I have a couple of those around here.
Thanks for the lead, though. Sometime, when appearance counts, I'll definitely go back to Bad Axe.
Cheers,
Re: I don't want to show you the pruning saw... *LINK*
Marv
This is Mark Harrell's website. The different style screw sets he offers are options for when you purchase his backsaws. He will sell the screw sets separately also. He also offers different type backs as well to match the screw sets.
He makes some fine saws and is beginning to build quite a following. He's only been selling his new saws since last August and is making great strides in the saw market in such a short time.
He has a very professional looking website. This guy is serious about what he is doing.
Marv
http://www.badaxetoolworks.com/
