A restored Keen Kutter K6C
Dominic in Buck's County PA
Hi gang,
Some recent questions about cleaning planes got me thinking that it was about time I took care of a Keen Kutter K6C I got off of Ebay about 8 months ago. I've been keeping my eyes out for Keen Kutters for a while after I learned they were just early type Bedrock in disguise.
I chose to use Evaporust this time for rust removal so I went to Harbor Freight (armed with a 20% off coupon) and picked up (2) 128 fluid oz bottles for $17.99 each (less 20%).
Here 's some photos of the plane before I started the cleaning process.
After disassembly, I planes the parts in my new High Tech Evaporust "dunk tank". It's really just a 30" long section of 4" light wall PVC sewer pipe with a pipe cap glued onto one end.
Just a note here for those interested or curious. Once a No 6 sized plane is dropped in, one 128 Fluid Oz bottle of Evaporust will fill a 4" dia pipe up to about 27". So, in theory one bottle will be enough to totally submerge and clean a No8 plane.
After letting the parts sit over night I drained the Evaporust back into it's container. I used a paint strainer in a funnel to catch any stray bits of gunk before they got back into the bottle. As mentioned previously, the parts come out slimy. And the finish is kind of gray on all the ground/machined surfaces.
But after wiping them down with mineral spirits and a very light touch up with a brass wire wheel brush (installed in my lathe) I was able to get them to look like this:
This represents about 30 minutes worth of "easy" work with a brass wire wheel brush. And THAT'S why I use Evaporust. After flattening the back of the iron, I reground the bevel, cleaned and polished the chip breaker, and then turned my attention to the rosewood tote and knob. These were really in fantastic shape and needed only to have some white paint removed. A quick wipe with lacquer thinner followed by several coats of sealer, then several coats of blonde shellac, then buffing out with 0000 steel wool and wax left them looking clean. But not overly shiney.
And now the reveal:
As you can see this plane is in excellent shape. The japaning is almost 99% and the iron looks like it only got ground once or twice. It's nearly full length. And once sharpened it was able to take a full width shaving with little effort.
Thanks for viewing!
See ya around,
Dominic
