Update on chair leg repair
I thought that I would post this afresh as the original is a while back now.
As a reminder, we started with the good ..
.. and ended up with this ...
I decided to glue up everything using West Systems epoxy, recognising that the one side of the break - the side that had staggered leaves, should create a strong join - but the other side - the side with an in-line break - would require reinforcing ...
The leaves were glued together over three sessions. At the end the joins were pretty good - there will be tidying up later - and just one gap evident ...
Luckily, this gap was precisely where I planned the reinforcing would run. My plan was to mortice along the side and epoxy in a 1/4" wide x 1" deep Beech insert (the chair is Beech, just in case you were not aware :)). This would extend from the foot of the leg to about 4" above the break.
Because the mortice would be about 1/32" - 1/16" below the surface of the rear most lamination, I decided that this was a job for my power router, so close your eyes if this part offends.
Here is the set up ..
The router (my trusty Elu 177e that I have had about 20 years) is supported on runners clamped to the leg.
Here is the router bit over the hole ..
Ok, I will jump ahead - the mortice was squared up, the insert epoxied in, and the excess planed away after it was set. This is the result ..
and ..
I have now to use a cutting gauge on the insert to mimic the layers of lamination, and re-shellac (amber shellac) the finish. It is feeling strong.
More after the weekend.
Re: Update on chair leg repair
Coming along
Pam Niedermayer - Austin, TX
Now, see, that you even have a power router says more than you'd probably like. :) And here I was feeling guilty about my foot mortiser. Leg looks good, very good.
Pam
PS When you guys described your sons launching into a chair, I was incredulous; but then I noticed how my Baldric, easily 115 lbs, launches himself onto the bed for his self-described cute begging routine whenever I change clothes to go out. Only difference is our bed is a futon on the floor (my great grandmother's trick for maintaining mobility into her 90's).
wilbur
Actually, I'm impressed that Derek's chair lasted through his son's teen years. Having seen the destructive power of my 7 and 3 year old boys, I'm planning on finding them alternative living arrangements when they hit their teens. ;)
Moses Yoder
How to raise children
Moses Yoder
To raise children, put them in a box and feed them through a hole. When they hit the teen years, plug the hole.
scott grandstaff
Love your Grandma!! OT
scott grandstaff
I sleep on the floor too.
I'd be paralyzed with a bad back otherwise.
Wore it out years ago.
When I got to a motel I don't care a bit about the bed.
Only thing I want to see,......... is how clean the carpet is!
yours Scott
Re: Love your Grandma!! OT
Oh, yeah, count on it. I suspect that pallet on the floor was necessity to start. She and my great grandfather grew up during the civil war and he supposedly fought in it, but he was a child, so I doubt it. At any rate, it couldn't have been much fun living in Richmond at war's end. Sleeping on the floor combined with McKenzie exercises have saved my back.
Pam
