Is there a chair doctor in the house?
Here is set of chairs that my father designed in the late 1930's. Bentwood laminations of what I think is either Beech or Ash. I restored the chairs several years ago ...
A side view of a chair leg:
This evening my son (the 17 year old with muscles like walnuts) sat down hard and the chair leg collapsed!
The one piece of luck is that the front lamination is still whole, and this means that I should be able to repair the leg without it showing from the front ..
Here are details:
The break is over the tenon ..
I can push the top sections back, and I think that these can be glued back as is, if indicated ..
This leaves the lower section (made up of three leaves) ..
Is there is any point in trying to glue back these pieces as they will not be supported? Even with epoxy. Some surgery is needed.
I have solid Beech and Ash boards that can be used in the repair.
How would you go about this repair?
Regards from Perth (where it is pretty late inthe evening)
Derek (about to head for bed)
- bummer
