honing mortise chisels
les winter
I can hone chisels on bench stones free hand. But I really like to use honing guides. Particularly so when I have ground a tip out of square. I use a LV Mark 2 and it is great. But it won't take my Iles mortise chisel. The chisel height is too great.
My Eclipse-style guide has only one narrow wheel and is too tippy.
Today I found a solution. I have an old LV honing guide. The original one. It will take the chisel height, but it is a bear to center and square up a narrow tall chisel. The Iles in particular, have rounded backs and they slide all over the place on the guide. My solution was to take 25 strokes with a triangular saw file along the center-most guide line inscribed on the LV honing guide base. Follow up with a larger triangular file and then a rat tail file to widen the slot.
Works like a charm. My Iles chisel back rests in the groove, tightening up the screw sets it firm. My bevel tip is again sharp and square.
Re: honing mortise chisels
Chuck Nickerson
Excellect solution! Thank you. As an added bonus, it uses the Veritas guide, so the handy micro-bevel feature is still in play.
