Miter saw question.
Bruce, a MN Galoot
Last weekend, I found the first honest-to-goodness old tool in this old tool heck town, a Langdon Acme miter saw. It's in pretty decent condition, but today is the first that I've had time to take it for a test drive. Square cuts are dead on, but I noticed that the saw wasn't dropping all the way down to cut completely through. So I dragged the saw out and found that the teeth in that center cutting range are very dull. At the toe end, there are one or two teeth missing, and at the heel it's evident that this saw has been sharpened a fair amount. The blade is 3-3/8" deep at the toe and 3-7/8" at the heel, total length is 24-1/4".
So the question. What would be the normal rake and fleam angles for this critter? Are there any special sharpening conditions I need to watch for? If it's not too difficult I think I'll take a crack at this one myself. OTOH, if the advice goes the other way I'll send it out for an expert job. The teeth line up fairly well, that is, there is no noticeable crest or dip.
Thanks.
Bruce, ultra glad not to be on night shift for another month.
I caught it on a trip to Canada about 15 years ago, with a spinner I made on a rod that I built. I would cast the large spinner (about 4" blade) up towards the weed beds and retrieve them just under the surface so I could see the pike hit it. This pike hit when I was fishing in a channel and cast between 2 weed beds and started retrieving just under the surface; I could see the flash of the spinner and suddenly this huge head came up and grabbed it; it was quite an experience.
