accurate inlay
accurate inlay
accurate inlay
eliot d
I asked this question over at Message Boards and for the most part was encouraged to use a router, but I thought I would ask over here. I want to set a rectangular(about 9x12in.) router lift plate that has rounded corners in a flat board. A superb furniture maker I met said the really accurate way is to knife around the plate and go from there, but I didn't ask him for details. Perhaps one has to consider the project as one of inlaying the plate in a fine piece of furniture instead of merely setting it in a router table. So what do the hand tool people say about how to go about it with hand tools?
Re: accurate inlay
Re: accurate inlay
Wiley Horne--So. Calif.
Hi Eliot,
Caveat: I haven't done the job you're describing. I assume you want the lift plate flush with the router table.
Thoughts: Doing this job with handtools is considerably simplified if you can laminate the router table, because that would obviate having to do a precision job of digging out a 9x12 field to a precise depth.
What I'd do is make a surround for the lift plate that is the right height. Then screw/glue it down onto the base of the router table, centered over the spindle hole.
For example, suppose the lift plate is 3/8" thick, and you want the total thickness of the router table to be 7/8" thick. Then the strategy is to make yourself a 1/2" thick base that is 16x20, or whatever the overall table size. Then make yourself a 3/8" thick panel that is also 16x20 (or whatever). Position the router lift plate where you want it on the 3/8" panel, and clamp it down so it doesn't move. I would pencil around the lift plate, and key everything to the inside edge of the pencil line.
First make the corners. Figure out the radius of the corners of the lift plate, and match that with a drill--Forstner or brad point. The key thing is that you don't want the drill to skate. So you need a way to exactly register the drill onto your 3/8" panel. I would locate the drill at each corner by eye, so the drill matches the inside arc of the pencil. Then press the drill into the panel, so that it's brad point marks the spot. Take a scribe and deepen that mark. Then chuck the drill into whatever you're gonna use--I'd use a brace--register the brad point into the marks you've made, and drill straight through the 3/8" panel into wood backing (so you don't have a mess on the backside).
Now connect the dots. You have a pencil line which connects the holes you've drilled, and is tangent to them. Clamp a straight edge alone each of those four straight lines between the holes, and knife along the straight edge, so that you have knifed the inside edge of your pencil lines. You are later going to register a chisel in those knife lines--that's why you want a physical mark.
Now saw out the bulk of the waste, going as close as you dare to your pencil lines. This is the great saving of the lamination method, because you just saw out a hole in the 3/8" panel, and don't have to dig out a precision recess in solid stock with a hand router.
Now take a chisel (they always say a 'sharp chisel', but sharp is understood with any hand tool--otherwise they don't work). Take the chisel, and nibble away the waste until you're very close to your knifed lines. The final chisel cut is registered in the knife line--just lean over onto the haft of the chisel and drive it down with your body weight.
Test against your router lift plate, and make any fine adjustments with the chisel.
This whole method is predicated on your being able to find a drill that is the exact radius of the router lift plate corners. If that isn't possible, then we have to talk about gouges......
Wiley
Re: accurate inlay
Jack Guzman from Maine
Re: accurate inlay
Using the scribing method your friend mentioned,lay your plate down where it goes.Scribe the outside with a sharp knife. Remove the plate and deepen your scribed mark.Using a chisel level out the inside to the depth you need. A router plane is the ideal tool for this job. Just set it to the depth you want.With a chisel it's more work getting it level.(a powered router would work too but we don't talk about such things on this side) ;)---Jack
Re: accurate inlay
Re: accurate inlay
As I understand it, there are two ways to go ...
(1) Saw out all the waste except for what will become a rebate around the perimeter of the cutout. The outline of the plate should be knifed first, then the centre sawn out, leaving the outer section to be turned into a rebate. Use a chisel and router plane for this.
(2) Mark and saw out the entire plate dimension, then add (screw-in) supports for the plate. The lift may then be suspended from the supports instead of a rebate. All you need by way of tools is a jigsaw.
Re: accurate inlay
Re: accurate inlay
Warren in Lancaster, PA
Eliot, presuming that you are skilled with an electric router, here is what I would suggest. First mark the perimeter of the insert with a knife as your friend suggested. Then using your router, rout as close to the line as you can, say 1/16 or closer. Then put a chisel right in the knife line and chop down all around. I have seen a beginner do this with a chisel.Then you can use the chisel with the bevel riding on the floor of the recess to remove the stuff you have chopped. For the rounded corners a gouge with the same (or slightly smaller) radius would be ideal; a narrow chisel would be a little sloppier.
Re: accurate inlay
Re: accurate inlay
ThomD
Google installing purfling, lots on youtube also. Basically a marking gage cut from both sides, and then bend over a hot iron and install with as many midway joints as are required.
The key to gluing it up it to tape the purfling on, then hit it with very thin crazy glue. Much easier than the other methods.
Both hand and router methods give perfect results in the right hands, but it is probably easier to do it by hand on a one off, no set-up, and easier to control against a blow out.
Re: accurate inlay
suggested slight modification
Ian Neuhaus (in Sydney, Australia)
Derek suggested:
My modification to this is:
The outline of the plate should be knifed first, then use a chisel and router plane to form the rebate around what will become the perimeter of the cutout. Then saw out the cutout. Done in this order -- rebate then cut out -- the centre of the cutout is there to support the router plane (or tailed router) while the rebate is formed.
cheers
Ian
