Chair caning repairs
Jack Guzman from Maine
I am repairing the broken back on a caned chair. The field is woven cane held into a groove with a strip of cane spline. I got instructions on how to replace the old material with new but no clue on how to remove the old. I tried soaking the old spline with hot water and prying it out with a bent chisel made for the job but it is a struggle. Does anyone know of a way to do this that doesn't require cursing? thanks---Jack
Re: Chair caning repairs
Wiley Horne--So. Calif.
Dunno, but is it glued? If so, maybe heat gun applied with care, so as to not mess up any surrounding finish.
Wiley
I'm sure it's glued. Hide glue I believe. I haven't tried a heat gun but hot water doesn't make it any easier. I'll soak it and try the heat gun next.---Jack
For what it's worth
the descriptions I've read of how to install this type of caning do refer to glue on the spline.
Mark Grable
In the shop I worked in 20 yrs ago, they used two different methods to remove the old cane/spline. Step one in both cases was, using a sharp wide flat chisel, pare cane/spline off to level of seat or back. This would sound like zipper when done quickly, and was kind of fun. Step two was a router with a 1/8" bit set to cut the full depth of the grove, about 3/8" (?). The router had a short disk of wood screwed to it, with the the through hole drilled off center so the screw could be loosened and the disk turned slightly, and so the distance from disk to bit could change. The distance needed to be greater than the distance from edge of frame, the guiding edge, to the center of the spline grove. Plunge into the spline, with the guide against the frame, and move the tool forward or back. twist the tool to adjust the cut in the grove. Maybe we did progressive cuts, 'cause the glue would get hot and burn. Breure backs were all curves, so the router coulden't be used. So we put the piece in a vise, and used a 1/8" mortise chisel to chop and chip. Once you're cut a vee, chop straight down about 3/4" away and lever out a chip. Chop again about 1/2" away and strike horizontaly with the hammer (mallet I should say) against the chisel back, like using a sand wedge maybe, only the divot is a piece of spline, hopefully with presscane as well. Step 3 is paring the sides of the grove clean with sharp wide chisel without making the grove wider. Remove all glue. Do not use Nomi or any other fine tool for this job! Please.
Stephen Shepherd
Stephen Shepherd
Jack,
I don't know of a single method that doesn't involve cursing. I always underestimate the amount of time it will take and I keep raising my prices. I just work out as much of the spline as I can with a narrow chisel.
I then put hot vinegar in the groove and let it soak. It can take repeated applications and scraping the crap from the groove. %^(&^$#. If you are lucky it will be hide glue, but newer chairs or modern repairs use modern glue. (*^&%$#. Use hide glue when you re-glue the spine to reduce future cursing.
Stephen
I got lucky. It's hide glue. I tried a few things and found a method that works for me. I just use that bent 1/8" chisel I got for the job and a mallet and starting at one end,chop and lever. If I take my time it goes smoothly. Afterwards I'll do the soak and then scrape. I bought the tool from LV but was surprised when I read their instructions for spline installation. They say to apply a bead of pva glue to the groove. I will not be following that instruction.---Jack
